Car
Car
Posted by berny13 on Monday, July 19, 2004 5:05 PM
<A TITLE="Click for more information about car" STYLE="text-decoration: none; border-bottom: medium solid green;" HREF="http://search.targetwords.com/u.search?x=5977|1||||cars|AA1VDw">Car</A> is in red and underlined in the Auto forum. When I click on it it takes me to another site. Is it just on my machine or can other members see it? Has some one hacked on to the web site in the form of advertisement?
Berny
 Phormer Phantom Phixer
On the bench
Posted by David Voss on Monday, July 19, 2004 5:22 PM
Ah, you're infected with adware/spyware -- whatever you want to call it. I'll find the link to how to correct it.
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
Posted by David Voss on Monday, July 19, 2004 5:34 PM
Adware, Spyware, and Malware
Best thing to do is download a copy of Ad-aware 6.0 if you already don't have it installed.
http://www.lavasoftusa.com/software/adaware/
Posted by berny13 on Monday, July 19, 2004 7:05 PM
Thanks David. I have Ad-aware 6.0 pro on my system and ran it. It corrected the problem. Now, how it got past my firewall is my next problem.
Again, thanks.
Berny
On the bench
Posted by David Voss on Monday, July 19, 2004 7:28 PM
Well technically, your firewall isn't going to stop it. It's something your firewall may see as being okay -- which is why there are products like Ad-aware.
Just make sure you've ran Windows Update, keep your stuff current and use Ad-aware more often. Wink [;)]
I've never used the professional version. Does it have an option to run it in the background or something that could catch stuff before it infects your system? I might be thinking of Spybot.
    November 2003
Posted by shrikes on Monday, July 19, 2004 7:45 PM
Spybot Search and Destroy? I've been using that for the longest time, but i haven't seen any options that will let it run in the background... I have Spybot-S&D v1.2. Is Adware better than Spybot?
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
Posted by berny13 on Monday, July 19, 2004 7:47 PM
David
The professional version does run in the background at all times, unless you disable it. It will give warnings that someone is attempting to access your system or has detected suspicious data coming into your system. It will block all activity untill told what to do. You can set it up any way you like in the set up section. It is a PITA to set up though.
Berny
On the bench
Posted by David Voss on Tuesday, July 20, 2004 1:42 AM
For Spybot, there are a couple of features under the immunize section -- browser helper and miscellaneous protections.
Adaware and Spybot are both very good programs. It doesn't hurt to have both installed. Sometimes one might catch something the other doesn't.
Spybot also has a good tools section which I've found handy to have.
