Models for handicap
    September 2010
Models for handicap
Posted by AllPointsHobbies.com on Thursday, June 16, 2011 10:17 PM
Hi there,
I need your help.  I was contacted by a a lady named Lorraine.  Her brother recently had a stroke and lost the use of his left side.  Building models was something he loved to do.  Lorraine is trying to help him out by getting information about how he would be able to continue building models.  What do you guys think?  Do you have any suggestions for Lorraine?  I was wondering if he would be able to use a hobby vise or if any of you had any other ideas.  Lets put our heads together and come up with a solution for a fellow modeler!
Thanks
Ben Twehues
www.AllPointsHobbies.com
    March 2010
Posted by Scorpiomikey on Thursday, June 16, 2011 10:39 PM
I know when my poppy had a stroke he lost fine motor control, so maybe something like kids wood models to start with to get the motor control back, see how he gets on with that and let him move up when hes ready.
A bit like this.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    March 2010
Posted by Scorpiomikey on Sunday, June 19, 2011 3:34 PM
Also i think you would get more response if you renamed this thread "Models for the disabled"
My signature
    September 2010
Posted by AllPointsHobbies.com on Monday, June 27, 2011 11:01 PM
The wooden kits are a good idea.  I was also thinking of a Helping Hands clamp set since he only has use of one hand the clamps could hold the piece he is working on.  I Appreciate the help!
Ben Twehues
    May 2011
Posted by HisNHer Tanks on Tuesday, June 28, 2011 5:06 AM
Not wanting to be too critical, but I have a 'Helping Hands' item that has the two clamps and the central magnifying glass and I almost never use it, because it really isn't always that 'helpful'.
I myself am disabled, and while I have full use of both hands per se, my disability renders my energy levels almost non existent. That, and using my hands for anything really physical (just using a screwdriver for instance) can if I do it for just a bit too long, make them hurt considerably.
End result, I deal with a regular daily dose of frustration over what I once could do, but now can not.
The trick is to limit or severe restrict actions that slap the disabled person in the face with their disability.
That's why the challenge in this case is so high, as just one hand is going to be almost impossible to defeat. Not totally, but very close to it.
I have done it all, ie every sector of model making, cars, trucks, ships, planes, tanks and figures. But in the end, you rarely escape a need for two hands, the fine motor response required to hold something in fingers, as opposed to unfeeling clamps, while the other hand attaches a part to what is being held carefully in the opposing hand.
Just about everything needs assembly. Almost impossible to escape it.
Parts clean up, models simply don't come without parts clean up.
But you CAN do figures that lack assembly. Airfix has a very complete array of subjects from all time periods and all settings. Frontier, Napoleonics, WW2, Modern. They would only require a well thought out system to hold the item while he painted it from all manner of angles. And as most of these figures come with a base, you get something to clamp onto which is all the difference. The base can be clamped without fear of damage, because he can always attach to a better scenic base later. Or he could approach it as part of the initial work. A wooden block screwed onto a holder from underneath would give a very secure mounting.
Then it's all about patiently positioning, then painting what is available from the current angle, and just keep repeating that process.
But then you get to how to open a bottle of paint.
Regardless of his solution, he WILL need a partner, someone that simply is ok with being an active participant in his hobby. But I am assuming he will require someone to aid him in non hobby activities as well, so I suppose it is not going to be such a stretch that he will have someone available to do no account tasks like open or close up a bottle of paint.
I think the key to the whole deal, will be to sell him on the value of what he chooses to do.
I have sat here staring at all of my models, and try as I might, I can't picture doing even the most featureless, bland looking tank with one hand and a helping hand grabber. Not 100% impossible, but perhaps too likely too be too frustrating that I would feel good about being too positive with suggestions.
In addition to the Airfix figures that are made of a soft plastic and come in a 1 piece item for the most part, there is also the fantasy metal miniatures popular with the role gaming crowd. Not very military admittedly, but I need to some times remember, the world is not just tanks :) They are also non assembly in most cases and really just a challenge to paint. Then it becomes all about eyesight, and not so much about having two hands.
I hope this helps, and remember, it's coming from someone that lives with very real daily frustration.
It will be a hard sell, getting him to believe.
Tamiya 1/48th scale armour fan
    April 2010
Posted by wastedyears on Monday, July 11, 2011 2:31 AM
I'm not sure if this will help, but here goes.  I started building models about a year ago, after I became disabled.  To make a long story short, my Dr.s told me that because of my disability I would lose a lot of my fine motor skills, particularly in my hands, as my disease is degenerative.  So I turned to models.  At the time, I was constantly dropping things, or having spasms in my hands and fingers that would cause me to suddenly make a fist or have my fingers instantly splay out and shake, etc without warning.  It was very frustrating, to say the least.  But over time building models has forced the muscles and nerves in my hands to kind of overcome a lot of this and while I still have some of these same problems, it doesn't happen nearly as often as it did.  So if your friend is able to do some modelling, even just a little, it might help him to regain some of his motor skills over time.  Kind of like physical therapy in a way.  It will probably be very frustrating for him, and progress may be slow.  While your friend and I suffer from different conditions, building models, even for very short periods of time, eventually did help me.  I was only able to tolerate about 5-10 minutes of modelling a day at first (on a good day!), but eventually I did see some improvement.  And by the way, I also use the Helping Hands, and while it isn't perfect, it does make some tasks easier for me, and it might help him.
Also as a side note, there is a movie called Sunshine Cleaning (or something similar), which has a character who is a one armed modeller.  He is only in a few scenes, and I know its only a movie, but maybe you might see something in those scenes that could be useful, or maybe just see how the character does his modelling and see something that could apply to your friends situation.  Hope this helps.
    August 2006
Posted by HawkeyeHobbies on Monday, July 11, 2011 1:36 PM
Modeling with out the use of hands is often more of a challenge than the modeler wishes to deal with. Though there are kits which require less attention to detail, have larger parts but often too are not satisfactory to the modeler who passed that quality/ability long ago. It becomes a mindset to change back.
Instead of subjects such as aircraft and vehicles, one might consider figures.
Gerald "Hawkeye" Voigt
    September 2010
Posted by AllPointsHobbies.com on Tuesday, July 19, 2011 9:51 PM
Thank you for the responses.  All are great ideas that I will pass along.
Ben Twehues
