Revell Phantom II 1/32 kit 4754
    September 2011
Posted by egymodler on Friday, September 30, 2011 11:02 AM
Hi every body,
its my first post and i feel shy to ask help from the first beginning Embarrassed
I got this old kit of Revell with no instruction sheet nor a decal one !
can any one help by sending a copy of these ?
Regards,
Doc
    January 2011
Posted by Tal Afar Dave on Tuesday, October 4, 2011 8:12 PM
Hey Doc, You might want to check the Revell website.  I took a quick look and didn't find anything on there.  Keep in mind that model companies change kit numbers every so often but the kit is basically the same.  Which model of the Phantom do you have?  I have a couple of F4s in my stash, but I'm not exactly sure where I put them.  You may want to give Revell a call or write them.  Here's the contact info:
Instruction Plans
Revell plastic model kits, please contact us at:
Revell, Inc.
1850 Howard St. Unit A
Elk Grove Village, IL 60007
Phone:             1-800-833-3570
Email: cservice@revell.com
Don't worry about being shy; this is a good place to hang out and learn from other model builders.  I've only been on here a while, and it is a blast!
Welcome aboard!
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    October 2003
Posted by se5022 on Tuesday, October 4, 2011 8:48 PM
what's the kit number? I may be able to help you out! Can you open a .pdf file?
    October 2003
Posted by se5022 on Tuesday, October 4, 2011 8:49 PM
disregard- the kit number is in the header.  Been a long day....
    September 2011
Posted by egymodler on Wednesday, October 5, 2011 5:37 AM
Hi every body,
thanks  a lot for your replies, the model is phantom II F-4F, scale 1/32, the skill level is 5, this my first time to build level 5 -but many of level 4- before that ,including phantom but from Tamiya and Hasegawa, so i don't want to spoil this fine extra detailed model by attempting rebuild with no available instructions.
PDF format is OK,
regards.
Doc.
    October 2003
Posted by se5022 on Wednesday, October 5, 2011 9:31 AM
Hey Doc-My instructions are for an F-4J.  Do you still want hem?
    September 2011
Posted by egymodler on Wednesday, October 5, 2011 12:22 PM
Well, is it in the same scale 1/32? if yes, may be i can get some benefit.
    October 2003
Posted by se5022 on Friday, October 7, 2011 5:27 PM
send your email address to ruffneckjc@gmail.com
    September 2011
Posted by egymodler on Sunday, October 9, 2011 3:49 AM
Hi,
sent already,  nozokiki58@hotmail.com
    September 2011
Posted by egymodler on Monday, October 17, 2011 5:43 PM
Hi,
thanks dear se5022 for sending what you have.
still in need for the original instructions as the landing gear is different also modified detailed cockpit.
