Removeable work stations
    June 2010
Posted by Temujin on Thursday, November 24, 2011 11:11 AM
Hi everyone. I don't have a whole lot of posts, and only come here every so often, but I really enjoy this site. The modelers here are light years ahead of me, for sure.
It's a bit frustrating at times when I struggle with a build, but in the end, I really enjoy modelling, and that's the bottom line, isn't it?
Anyhow, I just wanted share a tip that may be useful to some. The work area in my fort is kinda small, so this mother of invention has solved my space problem, and then some.
I got hold of of an old styrofoam cooler lid, fair sized. That's my substation. It's for working on a certain part of a build, or even if you have multiple builds going on at once. (which, by the way, I could never do. I have to be working on one thing at one time. Multiple builds are for madmen.)
So, as you can see, this little hunk of styrofoam holds everything you need for that certain part you're working on. Paint, blades, brushes, tweezers, glue, sandpaper, etc. The beauty part is the fact that it's styrofoam. Whatever you're using can be stuck right to it, nice and neat and secure.
If you'll look, you can see a small tin pan. That has pins going through it and is awesome for hold small parts until you're ready to mount them.
Also, you'll see hunks of strofoam rubber banded around the part. These have a couple of metal rod going straight through them and into the styrofoam base. The keeps the part perfectly still and the small styrofoam doesn't hurt it at all.
The great part about this thing, is, I can just pick it up and put it on the shelf. Viola, instant room.
If something like this has already been posted, I apologize.
    September 2005
Posted by Sprue-ce Goose on Thursday, November 24, 2011 11:21 AM
.a COOL ( er )  idea  !!
Toast
Posted by VanceCrozier on Thursday, November 24, 2011 11:28 AM
Temujin
Yes. Yes they are thank you!!!! Wink Hmm, recycling styrofoam - there is little else that can be done with the stuff, so why not. Even the chunks that get used to package electronics etc. could be used for this. Yes
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    June 2010
Posted by Temujin on Thursday, November 24, 2011 7:04 PM
Yes, for sure. I have an area under my bench that has several pieces of different types of foam, all shapes and sizes.
Another great thing about it is that you can cut the foam into any shape you want. Custom fit for the job at hand.
    September 2012
Posted by evo_lover on Friday, September 14, 2012 4:25 AM
Does the styrofoam melt when you paint over it?
on th bench:1/35 Tamiya Tiran 5
    May 2009
Posted by Pawel on Friday, September 14, 2012 4:45 AM
That might happen with certain kinds of paint - lacquers for sure, maybe some enamels too. Acrylics should be safe. Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    September 2012
Posted by evo_lover on Thursday, September 27, 2012 3:56 AM
Thanks for responding
    June 2010
Posted by Temujin on Thursday, August 1, 2013 6:27 PM
How do, folks. Haven't been around for a while. Life gets busy.
Anyhow, I wanted to post this helpful hint, but I couldn't see starting an entire thread.
I've been streamlining my fort/workbench, and I found in a drawer 2 flexible magnetic strips. Maybe 6" long and 1" wide.
I put some double sticky back on them and affixed them to the front of a shelf directly in front of me.
Viola! A place to put blades, small drill bits, small files, pins, etc.
Up off the table, greatly reducing the risk of catching the end of a blade. I got poked once, not bad, but enough for me to get a small dish to put a blade in, so I always know where it is.
It's also good for putting a small amount of bbs  I might need to use for this or that.
Prepping for a build,  if there are bits or whatever you know you'll need, you can put them there, and they're on hand.
I also have one tweezer I use way more than any others, so that gets stuck there as well.
This might be old news to you veteran builders, but it's new to me. Hope this can be of some use to someone.
