Looking for Cargo Webbing...
    February 2012
Posted by Sean C. Frolich on Wednesday, February 22, 2012 1:40 AM
Greetings, all.
I've got a project in the works, and I need cargo webbing.
Does anyone know of a manufacturer who produces cargo webbing like you'd see on a tractor trailer in etched brass? I'd provide a picture of what I have in mind, but I haven't quite figured out the interface yet. Sorry 'bout that. Scale needs to be near 1/35th or 28mm, or at least it needs to work in those scales.
Any help y'all can give would be most appreciated.
Thanks,
Sean
Tags: armor
    October 2008
Posted by P mitch on Wednesday, February 22, 2012 4:31 AM
Try searching for 1/35 Camouflage net on Ebay, just had a look and there is a fair bit there. Not sure you will find it in photoetch however. I dont think I've ever seen that to be honest as it wouldnt look right to me.
If anyone else on here has seen it sure they will reply
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    August 2006
Posted by HawkeyeHobbies on Wednesday, February 22, 2012 7:46 AM
Time to pick up some small brass rings and some Chart Pak drafting tape or slice some masking tape into appropriately sized strips and make your own.
Gerald "Hawkeye" Voigt
Posted by gregbale on Wednesday, February 22, 2012 9:51 AM
Some of the race car aftermarket manufacturers do scale window netting (which is actually webbing). The common 1/25 might be about the right size, but I don't know if they make sheets large enough for what you're looking to do. It may be an avenue to explore.
Like Hawkeye, I've generally made my own--though I use sports ankle-wrapping tape instead of Chartpak. It's got a nice textile texture and appearance (plus it's thin and nice and wide), and the low-tack adhesive is easy to work with.
Greg
George Lewis:
