Preshading Question
    March 2012
Preshading Question
Posted by Kildlawyrs on Friday, March 30, 2012 10:29 AM
I have been gone from model building for nearly twenty years, but have decided to jump back in. One of the things that intrigues me is this process of "preshading". I do not believe I have heard of this before. Although I think I understand the general concept, could anyone out there give me a primer on how and why this is done rather than using the alternate weathering techniques I grew up with.
Thanks.
    March 2010
Posted by Hercmech on Friday, March 30, 2012 10:46 AM
In short it is spraying all the panel lines with a dark color prior to the final paint coat.  Pictures below
13151015
    January 2009
Posted by Griffin on Friday, March 30, 2012 10:49 AM
Nice work Herc! That's much, much better than mine. Embarrassed
    March 2012
Posted by Kildlawyrs on Friday, March 30, 2012 11:14 AM
Thank you for the reply. Yes, I gathered  that's what it is, but by question is this; Is the model first painted with the selected base color coat, and then a thinner coat of that same base coat applied in order to allow the shading to show through? What do you do when the base coat consists of several colors such as in a camouflage paint scheme?
    June 2010
Posted by DoogsATX on Friday, March 30, 2012 11:18 AM
You can also be more inventive with it depending on what you're going for.
The overall idea is to provide depth and variation to an otherwise uniform color, laying that complexity in beneath the top coat (then going over with a light hand). I've seen some pretty cool preshades using blues and browns and such underneath greens - or yellow, orange and pink underneath the red of a Japanese hinomaru. I also know some modelers who just paint the whole thing black (or brown or whatever), then just use the top coat to determine what shows through and what doesn't...
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    June 2010
Posted by DoogsATX on Friday, March 30, 2012 11:25 AM
Kildlawyrs
The model is first painted with a uniform color. Doesn't really matter what. The exception I'd make is probably for white or something like that where coverage is tough. It may make a ton of sense to get a good, solid white coat first, then preshade (you'd want thinner and lighter colors in that case), then white on top. I'm actually planning that for my PV-1 Ventura WIP.
For several coats/camo, unless you're talking mottling or something, I ALWAYS mask. I can get nice demarkation lines, but I use such thin paint that it's hard to keep a consistent line. Even with soft-edge masking (got a few methods I've found work well for that), I shade and paint one color, then mask, then shade and paint the next, rinse and repeat. Works well for me...
