Getting really frustrated !!!!
Posted by Anonymous on Thursday, November 17, 2005 2:53 AM
Since upgrading forum I'm pretty lost in reading new posts ... old style was easier to find new posts but now all 1938547859302 posts seam to be new ! yesterday I put option make all as read and today I have 529 unread pages  in aircraft forum ...
Really I'm giving up till somebody helps me and explain the secret what I need to do to see just unread topics since last wisit !!!!
TNX
    July 2003
Posted by Foster7155 on Thursday, November 17, 2005 9:26 AM
The best thing I've found (until they get a "Posts Since Last Visit" button) is to set your options in each forum.
1. Open a Forum
2. Go to the bottom and click on "Options"
3. Click on the "Date Filter"
4. If you visit at least once each day, set the filter to "Newer than 1 Day". (Or which ever limit you want) This will only allow posts to be shown than have been posted in the past 24 hours. NOTE: Setting the filter to "New Since Last Visit" DOES NOT work...at least for me. It just messes things up more than they already are.
5. Click the "Remember!" button. If you don't, all settings will default back after you leave the forum.
You're done...with ONE forum. You have to do this in every forum you visit.
This is what I've done and it definitely limits the results in each forum. Until there's a larger fix, it's the best I can come up with.
Hope this helps...
Robert Foster
Pensacola Modeleers
    November 2003
Posted by chopperfan on Thursday, November 17, 2005 9:38 AM
Thanks, Robert!!!
I have been trying to figure out how to do the same thing.  It will make looking at posts a heck of a lot simpler now.
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
Posted by David Voss on Thursday, November 17, 2005 11:19 AM
In the new forums, whether or not you have read a post is actually tracked in the database.  In the old forums, it was stricly based upon your last visit date.  You could have visited one day, didn't read anything, but everything would have been treated as though you read it.
When you're viewing the topic listings, you should see icons in the far left column.  They'll be blue if you haven't read them or a new message has been added.  They'll be greyed out if you have read the thread.  The link color should also change, but I don't know if that's a CS 2.0 feature or (more probable) that I have the colors set the same for both.
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
