Hot link Question
    July 2004
Hot link Question
Posted by matthew9 on Friday, October 27, 2006 1:23 PM
I was trying to insert a hot link in a reply and due to the new reply format I am unable to.
Is there a trick for links like the way pictures are inserted?
Matt
Posted by David Voss on Friday, October 27, 2006 1:51 PM
First, do you see the link icon?
If you do, then to create a link, you first need to type the text for the link and then click on that button.  That should display a small window where you can enter the link url.
FineScale.com
To create a link using forum code, type {url=http://www.domain.com/}link text{/url} but replace the {} with [] (square brackets).
FineScale.com
You can also use HTML, like this: <a href="http://www.finescale.com">FineScale.com</a> when you use the HTML mode by clicking on the HTML button.
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
    July 2004
Posted by matthew9 on Friday, October 27, 2006 6:27 PM
Cool, tried the 1st way on testing section. Worked great.
Thank you Mr. Voss
Matt
