I still don't understand how to...
    September 2006
Posted by raptordriver on Tuesday, February 27, 2007 6:44 PM
I've tried alot of things and I still don't know how to post Group Build badges?can anyone tell me here.Sigh [sigh]
Andrew
    February 2007
Posted by DesertRat on Tuesday, February 27, 2007 8:16 PM
Let's see if we can figure out where you are going wrong......
 Ok, do you have the GB Badge in question already made? If so, upload it to your hosting site (i use Onfinite, but many use photobucket here. Both are free).
Once it's uploaded, go to the block where it gives you the web link (it should start with an http) and copy that.
Then come back to the forum here and go into update your profile. In the signature block portion, you will post it just like you would a normal picture on a thread. Only difference is that you have to manually type in the [img]'s, with you pasting the GB Badge link on the page.
Before you save your changes, it should look something like this:
[img*]pasteyourlinkhere[/img*]
just like that, except DON'T type in the *
once you save your changes, check any post you left before. If you see nothing right away, give it about 10 minutes, since it takes a little while for the forum to update itself. Give it a shot, and if you are still having trouble, lemme know. Good luck!
Warmest regards,
Roger
    September 2006
Posted by raptordriver on Tuesday, May 1, 2007 10:43 PM
Thanks for trying to help me with this but I still don't get itDisapprove [V]Once I've done all those things at Photo BucketI copied the Groupbuild posters and only the letters showed up. What am I doing wrong?
Andrew
    May 2005
Posted by Bgrigg on Tuesday, May 1, 2007 10:59 PM
Use the IMG link. It's the one at the bottom. No need to type in anything. Just select the IMG tag, it will copy itself automatically. Then go to your profile page and paste it into the signature line box using ctrl and V at the same time. Then save your changes, it may take up to ten minutes for the server to refresh.
So long folks!
    November 2003
Posted by ilikespagetti on Tuesday, May 8, 2007 3:26 AM
Not to ask a stupid question but you are going by what you see after posting right? I've known people to think it just doesn't work because in the text window a picture  doesn't show up.
I am a man, But I can change. If I have to....I guess...
    September 2006
Posted by raptordriver on Saturday, June 2, 2007 8:47 PM
Thanks everyone Smile [:)] I finally got it although it took me half a year, somtimes I don't feel like I'm the smartest one.
Andrew
