Woody -- modified images for your sig
Posted by David Voss on Friday, October 24, 2003 9:02 PM
Hey Woody, I modified the image you were using in your signature. Instead of the bright green, I made it transparent. Hopefully it'll look good on both light and dark backgrounds. The original and the larger of the transparent ones -- you will have to click on them to display the full size. Otherwise the images get resized to 350px.
ORIGINAL
TRANSPARENT - 490 x 200
TRANSPARENT - 294 x 120
If you decide to use one of the modified versions, can you serve it from where yours is currently hosted? Thanks. --Dave
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
Posted by David Voss on Friday, October 24, 2003 9:07 PM
regular white background....
ORIGINAL
Posted by Woody on Friday, October 24, 2003 9:23 PM
Thanks David, That does look alot better. I didn't much care for the green and was about to give it the ax!Cool [8D]
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
