Validation Error occurs while attempting to post a Group Build badge
    June 2010
Posted by rocker286 on Monday, July 10, 2017 8:47 PM
Yesterday I had a bit of an issue when I tried adding a GB badge to my signature. As soon as I would try to update my settings, I'd get hit with a screen that said "validation error". I know this same issue has caused trouble for others. Does anyone have any ideas on how to fix this issue? Any help would be greatly appreciated! Cool
4badges
    August 2015
Posted by crown r n7 on Tuesday, July 11, 2017 9:04 AM
Hi Rocker Ive been waiting for an answer for a good while. I tried to make the badge smaller Ive tried different combo of badges Ive posted this same problem some time ago but it falls on deff ears I guess I.T. have better things to do. untill then I will do GB and collect the badge.
 Nick.
Posted by Bish on Tuesday, July 11, 2017 9:08 AM
Did you try and post it in addition to the one you have.
    June 2010
Posted by rocker286 on Tuesday, July 11, 2017 1:19 PM
Crown- that's what I did too! I tried re-sizing it and still nothing.
Bish- yep, I did try adding a new badge in addition to the one I already had.
4badges
Posted by Bish on Tuesday, July 11, 2017 2:35 PM
Thats the problem. The validation error has changed since the last time i got one, it used to tel you you had exces]dded the number of charectors, 512 i think. I am no computer wizard, but from what i understand, the charectors are the individual numbers, leter and symbols that make up a link. Add that to anything you have written, and it soon adds up. I did a test earlier and was able to have 3 images on my sig useing Flickr, that was more than i had with PB.
You have 2 options. Fiorst is to turn your GB badges into a GIF. The second is to put them all into one image, as i have done. You can see in my sig, this way you can have as many badges as you like.
But be warned, this can annoy people have such a large sig image, which is why i am only adding this as an example.
    August 2015
Posted by crown r n7 on Wednesday, July 12, 2017 10:39 AM
Well removed my text was able to add one more badge ! I finally used power point
 Nick.
