A Small Discussion About Wire Rope Hoist
    December 2010
Posted by sweetpea on Wednesday, August 29, 2012 3:25 AM
A wire rope hoist is a wire which comprises of many metal strands. A wire hoist is used for lifting up some loads as well as bringing them down. When a rope is used as the lifting material then the hoist is called wire rope hoist.
The weight is joined with the hoist with help of a hook. A hoist with rope as its lifting material has become widely popular presently. This kind of hoist is easily portable. Wire Rope Hoist is also perfectly designed for lifting heavier materials. A wire rope hoist is generally bigger in size than the high caliber chain rope hoist.
In a wire rope hoist generally spur gears are used. Wire Rope Hoist is made of alloy steel material. It is workable both in ball as well as needle bearing. Another important feature of Wire Rope Hoist gear is that it produces less noise. This instrument is really very strong and hard and it takes very low maintenance. In a wire rope hoist an electro-mechanical hoist brake is used which is totally safe. It looks like a conical disc. High braking torque is used in this kind of hoist. There is no need of using any brake coil in this hoist. It gives high performance and needs minimum maintenance.
To get more Info about  Wire Rope Hoist visit on – http://www.hoistsindia.com/hoists.html
