Posting test
    January 2021
Posting test
Posted by Teenage Modeler on Thursday, March 30, 2023 6:20 PM
Alright, guys. This is finally my F4U finished. I already finished it months ago, but I did not post it here because I was busy (sorry Sad) But, I am very happy with how it turned out. The last time I posted progress of my F4U was almost 9 months ago, and this is what has happened since.
So last time, I finished the cockpit, the tail gear, and the propellor. I told you guys about the problem with the main landing gears not being able to properly retract.
Anyway, I fixed that problem. What I did was everytime I wanted the main gears to retract, I just removed the tires and retracted the gear since it took little space (the strut, anyway).
Once I was done sealing the cockpit, I painted the engine. I forgot how I made the blue that recreated the R2800 Double Wasp's crankcase (I think it was Tamiya White and Blue together with grey mixed into it). I painted the engine aluminum, and the pushrods black. Once done, I sprayed the whole engine bay with semi-gloss and weatherd it a bit.
Pratt & Whitney R-2800 Double Wasp - Wikipedia
Because the engine is not separated from the front assembly (it's already molded in contrary to Tamiya engines), it was a bit hard to detail it. Painted the inside lining black to simulate depth and shadows.
I then sealed the engine with tape, and puttied some nasty gaps:
I sanded it down, and then I primed it with Tamiya Surface Primer L.
Once that's done, I sprayed a basecoat of XF-17 Sea Blue. Before spraying, I learned that the blue itself was too dark for smaller models, so I decided to marble in a lighter version of the XF17 ( I added some white and blue). This was the result.
You can see each panel with this technique, and I thought it was a good try,
Once I was done was that, I then sprayed gloss on top of the marbled coat to prepare for the decals.
The decals were a bit thick, but using Mirco Set and Micro Sol helped it to conform to the curves the plane has.
The final steps of the model were sealing the decals with Semi-Gloss. I weathered the fuselage a bit, and added some scratches from where the pilot will exit the cockpit.
I also added a smoke stain to where the exhaust is with Tamiya Buff and Flat Black. Once this was finished, I attatched the armaments and the bombs and rockets, and the propeller as well (which I have slightly weathered).
This is the final result.
Needless to say, I was very pleased with the result. I was able to make a good model even with the problems this kit has (fitment issues, manual problems). I was happy to finish this from the summer, and I again apologize for the long wait for this.
I hope you enjoyed reading about my model!
Teenage Modele
Made you Look
Posted by keavdog on Thursday, March 30, 2023 7:43 PM
Well done!
Thanks,
John
    July 2004
Posted by stikpusher on Thursday, March 30, 2023 10:34 PM
All things considered, you made the old bird look pretty good! Far better than I did with my dad's help 50+ years ago... Nice job on the classic kit. Yes
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2007
Posted by armornut on Thursday, March 30, 2023 10:41 PM
  Yessir that is a fine job on an old kit. I really like the fact that you painted the crankcase, accessory gearbox, bluish/grey. I have seen several of these engines on stands in museums and such yet forget to paint it on my models. Nice work TM.
we're modelers it's what we do
    January 2021
Posted by Teenage Modeler on Friday, March 31, 2023 10:02 AM
keavdog
Well done!
Thanks Keavdog!
Made you Look
    January 2021
Posted by Teenage Modeler on Friday, March 31, 2023 10:03 AM
armornut
I appreciate it!
Made you Look
    January 2021
Posted by Teenage Modeler on Friday, March 31, 2023 10:04 AM
stikpusher
Thanks for the comment! 50 years ago is a long time ago, and I can see that the kit was made from very old molds, which is why there are some fitment issues. I did enjoy the build though, and I hope you did too for your model.
Made you Look
