HI THERE JON
I would suggest the Lowe, as it has an air reciever and will provide a constant supply of air. The other types are ok but are hard to regulate the air pressure.
on my last compresser I could only use it at 20psi and this would drop to about 4psi as soon as I pressed the trigger, so I took it back to the shop.
I bought a Hardware store compresser (not a modeling one) which
Is great. I can regulate the pressure from 1psi upwards, and it was a lot cheaper than a modeling one even if it is a little large.
I used to use an inflated inner tube before I got a compresser, it worked pretty good I also tried canned propellant, WAAAAY TO DEAR MAN.
Yours Gotter
