Back into modelling after 20 years
Posted by Anonymous on Monday, January 12, 2004 6:42 AM
Hi all.I'm Paolo,36 years of age and live in the UK.I've just got back into modelling and i've bought Academy's B17 'Memphis Belle'.I've also bought a Badger 250-2 "cheap as fish and chips" airbrush as my budget is very small.I'm planning on using 'Humbrol' enamels and need some pretty serious tips on airbrushing as i've never done it before....
    January 2004
Posted by Theoden on Monday, January 12, 2004 6:56 AM
Hi and welcome to the forums Paolo!
I recently found my way back to modelling after 5 years...
The others will have a lot of tips concerning airbrushes and colors, you´ll see! I´m still too unexperienced here as well.
And maybe ´shrikes´ can provide You with some tips about the B-17. He loves this old lady as far as I know!
Posted by Anonymous on Monday, January 12, 2004 9:06 AM
Hello Paolo, basically the same story here except I've got a year on you. I meant to check in here, but scrolled right to the Space forum for my first (of many I'm sure) question. Making a trip to the local hobby store today, no set plan to buy anything specific yet.
-Neil
Posted by Anonymous on Monday, January 12, 2004 9:33 AM
Welcome to the forums, paoloski!
........And to you, fnord!
As for getting started in airbrushing, nothing beats practice. The best way, to get the feel for the brush, is by spraying on some white paper. You will be able to get a feel for how the paint flows. You want to shoot for a nice pattern or line, with minimal overspray or "spattering" Try this with lager patterns and smaller patterns. Another good way to practice, is on an older model (if you have one) It also give you a chance to test the brush with different air pressure. The best pressure (for me anyway) is between 7-15 PSI. I'm assuming that, you already have a compressor?
Another tip is to make sure that you have a moisture trap installed. All compressors will get droplets of water built up in the tank itself (the nature of compressed air) The trap will catch those droplets before getting to your airbrush and mixing with the paint.
As for mixing paint and thinner, a good rule of thumb is the consistancy of milk. Again, once you start playing around, you will be able to tell if the paint is too thin or too thick.
One major issue, that is often overlooked, is to keep the airbrush clean. Proper cleaning between uses keeps the brush in good working order. If not, you will begin to see the spatter or bad paint flow (not a good thing when painting the model you worked so hard on)
I know it's a lot of information but, just take your time and experiment. I used to paint strictly from a spray can until I finally purchased an airbrush. I have been using one for over 5 years now and don't know how I managed without it.
The painting forum can answer any other questions you may have.
Good Luck!
Posted by Anonymous on Monday, January 12, 2004 11:21 AM
Welcome back to the craft and to forum. I'm a brush man myself and haven't fully mastered it yet but there is lots of great help and ideas here.
    November 2003
Posted by shrikes on Monday, January 12, 2004 11:37 AM
Welcome to the forums, paoloski and Neil! I haven't been here in the forums for too long, but i've learned LOADS! (i wouldn't have found out about bare metal foil, future or even how to use putty with out the great tips here!)
Paoloski, I work on a limited budget too, and have yet to buy an airbrush (though i am eyeing a Badger Crescendo 175 i saw recently...). Theoden is right, i really love the B-17! I assume you mean Academy's 1/72 offering... if that's the case, then the photo you see in my signature (if it's working today) is that model. It's a good value for money (though i'm a bit peeved by the lack of detail in the interior, but then again it's 1/72).
You'll want to watch out for seams as the fusealage halves come together as there are so many little bits to make sure are in place. Also, Watch out for a seam where the cockpit windscreen meets the fuselage. And most importantly, i think you ought to strengthen the tail wheel. you can't see it in the picture, but the wheel strut has bent over time and it now rests on it's tail!
Tell us how it goes! Big Smile [:D]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    January 2003
Posted by shermanfreak on Monday, January 12, 2004 4:49 PM
Welcome to FSM Paulo & fnord amd welcome back to the hobby.
Enjoy the forums !!!!
    July 2003
Posted by Dwight Ta-ala on Monday, January 12, 2004 5:51 PM
Hi, Paolo & Neil. Welcome to FSM both of you guys.
Hope you enjoy the forum.
    January 2003
Posted by therriman on Monday, January 12, 2004 6:27 PM
Hi Paolo, welcome to the asylum. I'm sure of you peruse the airbrush section you'll come up to speed quickly. Great info over there.
Tim H. "If your alone and you meet a Zero, run like hell. Your outnumbered" Capt Joe Foss, Guadalcanal 1942 Real Trucks have 18 wheels. Anything less is just a Toy! I am in shape. Hey, Round is a shape! Reality is a concept not yet proven.
Posted by Anonymous on Monday, January 12, 2004 7:15 PM
Welcome to the forum, Paoloski & fnord !
Browse through the painting & techniques pages. There's TONS of info there.
Nothing beats practical experience. Try new things & experiment to find what works best for you. Its best to practice on an old kit, or one you probably won't build. You don't want to do any "experimenting" with a kit into which you've put a lot of hard work. And if you can't find answers, post a question. People here are more than willing to help a fellow modeler.
And above all, have fun & enjoy the site !
Posted by Buddho on Monday, January 12, 2004 10:25 PM
Welcome to FSM Paulo, and back to modelling...
I use a Badger Crescendo and have recently bought a Sotar 20/20 airbrush which I have yet to master. Enjoy yourself and see you around here...
Regards, Dan
Posted by J-Hulk on Tuesday, January 13, 2004 6:56 AM
Welcome to FSM, gentlemen!
~Brian
    June 2003
Posted by allan on Tuesday, January 13, 2004 8:52 AM
Welcome to FSM, Paolo. Check out the airbrushing forum. You could pick out a lot from there.
Sign - Welcome [#welcome]
No bucks, no Buck Rogers
Posted by cassibill on Tuesday, January 13, 2004 11:43 AM
welcome, guys, welcome. I'm sure some one has the info you seek.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
    June 2003
Posted by M1abramsRules on Friday, January 16, 2004 9:05 AM
Welcome aboard! hope you enjoy the forums
Posted by Anonymous on Friday, January 16, 2004 10:44 PM
Welcome Paolo, enjoy the site!!
Posted by Anonymous on Saturday, January 17, 2004 2:48 AM
Hello and Welcome Aboard. Dig through the various forums and you will find tons of information.....Dont see what your looking for? Try the search feature its very easy to use and thorough! Still dont see it? Dont be shy ask away!
    December 2012
Posted by FreedomEagle1953 on Wednesday, January 21, 2004 3:56 PM
Hi ya paoloski ...
Just thought I would toss my My 2 cents [2c] into the fray ... and say howdy and ... Sign - Welcome [#welcome] !!!
FreedomEagle1953
Chicago, IL area
"keep on building 'em ... but don't glue your fingers together"
Posted by mark956 on Saturday, January 24, 2004 9:49 PM
Sign - Welcome [#welcome] to FSM paoloski.
mark956
    January 2003
Posted by Keyworth on Saturday, January 24, 2004 10:02 PM
Welcome to FSM and the forums.
"There's no problem that can't be solved with a suitable application of high explosives"
