G'Day - A return to the hobby after a very long time
    March 2011
Posted by Anokii on Saturday, March 26, 2011 9:50 PM
Howdy all,
Well it's been almost 40 years since I used to while away hours building and from what I've seen (and like everything else) it's changed dramatically (including the prices.. Smile). The amount of information available here and elsewhere is staggering. I'm originally from the US and now living in Australia and keen to get back into it all.
I'm planning on concentrating on 1/35 - 1/48 WWII armor with several diorama's already sketched out, a lot of practice ahead of me but to be honest I'm struggling with certain aspects as the old memory isn't what it used to be - if I could trouble someone for some tips that would be great;
- In a lot of articles I've noticed that people build their kits before painting whereas I used to paint everything on the sprue and then assemble and touch up - I was never lucky enough to own a airbrush back then but I will be getting one now. Is painting the 'bulk' of the model after assembly the way to go?
- I've picked up a Tamiya kit (SU-100) just for practice, as I want to concentrate on weathering tips I've found. I've had more than a hard time with smoothing / filling round objects (e.g. gun barrel and fuel tanks) and luckily this model isn't going anywhere as they look like ...., I've got a Dremel but couldn't really identify a tip that would smooth the seams - again any tips or suggestions?
- Considering I don't have a suitable garage / basement / shed to work in I figure acryllics are the way to go is a 'paint booth box' necessary for airbrushing?
- And finally if there are any Aussies reading this - any recommendations for hobby supplies (on-line in Australia or local Perth area) would be greatly appreciated - one locally is called Stanbridges which seems to be quite good but always interested in other suppliers?
Thanks and I look forward to getting back into it again.
Cheers,
Ain't nothing but a thing....!!!
Posted by Spamicus on Sunday, March 27, 2011 7:14 AM
Toast Welcome to the forums. This is the place to get your questions answered and pick up tips on just about everything. We've got several active members from Australia, you'll be hearing from them soon. As to your questions:
Build then paint or paint then build or something in between is basically a personal choice based on what works for you. I'm a build as much as possible then paint the whole thing guy.
Tamiya's soviet fuel drums are some of the hardest things to get the seams off of. MY tool of choice is a "Flexi-file" which is essentially a bow sander. It lets you sand away with pretty hard pressure before it starts to make flat spots. I clean the seam up as good as I can get it before assembly then put a small flat bead of green putty on the seam once it's assembled; then sand away. I don't know of an easier way short of after market fuel drums.
A paint booth isn't necessary, but I think you'll find it makes life much easier. I built one from a stove exhaust hood and some rubber maid tubs. It's portable and I can just toss the vent hose out a window. Haven't heard the wife complain about fumes since I started using it.
Once again, welcome aboard; I'm sure some of the other guys will be giving you some input pretty soon.
Steve
    April 2015
Posted by spadx111 on Sunday, March 27, 2011 11:52 AM
Welcome Sign to the forumsWelcome Sign.
Ron
    July 2009
Posted by 40.mm on Sunday, March 27, 2011 12:17 PM
welcome to the forum this is the place where all your questions will be answered . got a great bunch here willing to help, they sure helped me a lot and you might get a laugh or two.
http://www.vairhead.net/forum/dhg.jpg
