My questions regarding paint brushes were more-so about size. What is 1-0?
A round, fine-pointed brush with a single "0" on the handle.. A 2-0 is coded "00", 3-0, "000", so on and so forth... As the number of zeros increase, the size of the brush diameter and it's point decrease...
Here's my take on this..
Good, 0, 1-0 and a 2-0 red sable brushes are all you need to start with as far as detail-painting brushes go... The "00000"-types hold so little paint they're about useless outside anything but painting eyebrows on 1/48th scale figures.. they're expensive, but what you're paying for is the point, so take care of it.. Lick the brush back to a point after cleaning it, and put the tube back on it when not in use..
I prefer Grumbacher red-sable round brushes, m'self... Master's Touch makes really good flats.. (A flat is just what it sounds like.. It's a flat brush with bristles that are about a 1/4 inch long and vary in width.. I use 1/8th, 1/4th mostly.. But a good 3/4 inch is neded sometimes too, especially for weathering..
But don't get tied into on-line HOBBY shops for brushes.. Hobby Lobby sells an extensive line of brushes, and you can use the discounts on their web-site, not just "in-store"... They generally run about 30-50% the price of a "Hobby Shop" brush... Same with oils and pastels.. Look for art-supplies, not modeling supplies when it comes to brushes and certain paints like oil starter sets and pastels starter sets..
For cements, All you really need to get started is a bottle of Testor's pink-label and a bottle of Testor's ModelMaster Black Label (the one with the needle-tube applicator.. ) You don't need the Tube cement, unless you really need a lot of time to adjust parts-fit.. It's better to dry-fit repeatedly before cementing once... The Black-label will allow you all the time you need, really.. Apply the pink label with a 1-0 brush... The cap-brush is useless..
You apply it by holding the parts together, then dipping the brush into the cement bottle, then touching it to the joint.. Capillary-action will carry the cement a couple inches in either direction to form the bond..
Frankly, the current issue of FSM does contain more than enough for you to get started back into the hobby... It's not a list for kids to get started, it's a fairly comprehensive list of stuff that you need, and a "part II" of stuff it'll be nice to have later...
Also, make use of this place in it's entirety, not just the forum for a specific model genre... Check the articles, the videos, glossary, tips database, etc...
90% of what you want to know has been written down already in here, so play around with the search function, get to "know your way around".. It's a tool ( the website), same as your X-Acto Knife or Sprue-cutter...
When you ask questions, ask good, to the point ones, like you did earlier here.. "My questions regarding paint brushes were more-so about size. What is 1-0? " is exactly the type of question that'll get you timely answers, and ones that you can use.. Questions like "What's a the best P-51 Kit?" is a lousy question... Asking "What is the most accurate 1/48th scale P-51D for under 30.00 Dollars?" is FAR better...
When you're starting a question in a forum, the title requires a little thought too.. I love to help a guy out, but I tend to gloss over htreads titled, "Question?" or "Quick Question"... Titled "Question About Monogram P-51D Cockpit Colors" is a great title, and you'll get answers far quicker....
Anyway, that's just my two centavos... Welcome to party!
