How long are model paints good for ?
    February 2013
Posted by sturgejl on Saturday, February 16, 2013 6:26 PM
My first post here at FSM. I came back to modeling two years ago after a twenty plus year absence, wow has everything changed. My interest is WW II Navel aircreft, both US and Japanese. I am currently building the old Revell AT-6/SNJ Texan. I was airbrushing the inside cockpit using MM interior green FS34151 and my airbrush kept clogging up, I had to clean my airbrush 3x before I finished. This has never happen before. I was wondering if maybe the paint was outdated or what not. I have used MM paints before and did not have this problem. I was wondering if some of you could give me some advice as to why this happened so it won't happen again. I have tons of questions to ask the old timers but I'll start with this one. Thank you for any suggestions you may have.
Moderator
    September 2011
Posted by Tim Kidwell on Sunday, February 17, 2013 8:59 AM
Welcome to the Forum, Sturgejl! We're glad to have you here. I'm sure someone will chime in with some airbrushing advice, but, you may want to post your question over in the airbrushing category, too. That will ensure maximum coverage.
Tim
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
    August 2011
Posted by Centerdeck2 on Sunday, February 17, 2013 10:05 AM
Paints are generally good up to the time after you just left the hobby store and right before you go to use them.
Shepherd Book once said to me, "If you can't do something smart, do something right."
    July 2004
Posted by stikpusher on Sunday, February 17, 2013 10:44 AM
In the past few years I have found that Testors seems to be having some quality control issues with their products that vary from batch to batch. I stopped using their liquid cement because the last couple bottles that I had used were about as effective as sugar water. Paints have had had different issues, adhesion, thickness, clumping. I suspect that some formulations have been changed for environmental law reasons. But that is just speculation on my part. All that being said, I do have some old paints (some are 25+ years) of various brands that still work great, and newer ones of the same brands that have had variations of the same issues that I listed above. Even when they are all stored together. With you older paints, you will just have to test each one individualy to see if they are still usable. My only suggetion is that you make sure that your paints are mixed thoroughly by stirring (not shaking) befire using them in your air brush, and of couse that they are stirred again after being thinned for air brushing.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Dre
    June 2007
Posted by Dre on Sunday, February 17, 2013 11:07 AM
When it comes to Testor's/MM, Stikpusher nails it.
sturgejl, it sounds like you like have a different problem going on in your AB than old paint.   I've started to use lacquer thinner to cut my enamels and I've been really pleased with the results so far- significantly less tip fouling, clogging or clumping.   As a bonus, the paint really seems to adhere to the plastic a lot better with a more durable finish.
    March 2010
Posted by ACESES5 on Sunday, February 17, 2013 1:15 PM
I've got some MM paint here that are 10 years old and there just fine, as for clogging your AB make sure there mixed up good so you don't get clumps in your AB. What kind of thinner did you use, I use a good quility mineral sprits for MM and X10 thimmer for Tamyia paint. I have had some probluems with a couple of MM colors as stated earlier posts,so I just replaced them with Tamyia colors probluems solved. And as DRE and STICKER posted make sure there mixed good before using.   ACESES5
    September 2003
Posted by checkmateking02 on Sunday, February 17, 2013 2:32 PM
I have some paint also that is pushing twenty years old, and is still usable.
As to the clogging airbrush, I've taken to thinning the paint 50-50:  half paint and half thinner.  It means putting on more coats and thinner coats, but it goes on smoother, doesn't clog the airbrush as much, and stretches out the paint to last longer.
I also use lacquer thinner from the hardware store for thinning the paint and cleaning the airbrush.
It's also a good idea to completely disassemble the airbrush from time to time and give it a really good cleaning.  Simply spraying thinner through the airbrush after each painting session is not enough.  Paint will still accumulate inside.  I use a toothpick soaked in thinner to scrape around.  Don't know if this is necessary for all types.  I use a Paasche H model, which is pretty quick to take apart and reassemble.
Still, it seems clogging will almost always appear eventually, so keep a q-tip handy.  Dunk it in thinner, and wipe the nozzle of the airbrush when you notice it beginning to clog.  I also sometimes just submerge the tip of the airbrush during painting; do a quick shot off the model, and resume spraying.
Good luck to you.
    September 2010
Posted by mikeymize on Sunday, February 17, 2013 2:41 PM
For what it's worth I agree with you stikpusher about the glue; I switched to Tamiya liquid (Reg. & xtra-thin) much better now. As for MM paints I use their enamels and have been pretty happy I only use Tamiya for acrylic. Anyway, from reading what Testors said you should always use the airbrush thinner as opposed to regular stuff; they say it's stronger and designed specifically for that use. May or may not be contributing  to your problem. Anyway glad your back sturgejl to enjoying a wonderful hobby !
"Time you enjoy wasting is not wasted time".
    March 2004
Posted by subfixer on Sunday, February 17, 2013 4:11 PM
The advice that stikpusher gave about stirring the paint versus shaking is sound. I have found that shaking Testor's Model Master acrylics causes them to clump up and dry out for some reason. Maybe it's because the air in the bottle is making more contact with the paint that way.  Anyway, stir those acrylics!
I'm from the government and I'm here to help.
    July 2004
Posted by stikpusher on Sunday, February 17, 2013 5:22 PM
I am a HUGE fan of MM Airbrush Thinner for enamels. It works great with all the different brands of enamels that I have. Acrylics are far more picky and usually require a brand specific thinner for best results. I gotta second (Harrumph! Harrumph!) the airbrush maintenance advice about periodic disassembly & cleaning. Lacquer thinner and some good cleaning brushes help immensely.
       - Plankton
LSM
    February 2013
Posted by sturgejl on Sunday, February 17, 2013 6:05 PM
Thanks Stikpusher, I really appriciate the time you took to respnnd to the "new guy". I was thinking along the same lines regarding validity of different paints.
    February 2013
Posted by sturgejl on Sunday, February 17, 2013 6:10 PM
Thanks Dre, you may very well be right. clogging is exactly the word to describe what was happening. I have both lacquer and enamel thinners and will give them a try.
    July 2004
Posted by stikpusher on Sunday, February 17, 2013 11:53 PM
Anytime sturge. Happy to help out.
       - Plankton
LSM
    August 2007
Posted by DUSTER on Thursday, February 21, 2013 9:56 AM
   to the group;
 I second (or third or fouth???) all the advice about thinners and mixing.
  For me a basic rule of thumb is to use the manufacturers thinner  for each paint brand you're using and see how it works.
Then with the  several different thinners ideas you get, you can give them a try if you wish, see how they compare. Leaving you better able  to decide on the best combination that works for you.
Steve
