Airbrush
    December 2014
Airbrush
Posted by testpilot on Wednesday, August 12, 2015 10:07 PM
I'm interested in learning more about aoirbrush nozzels and needles. What size is
recommended for which purpose. I have a Grex double action side delivery airbrush.
and want to become more proficient in detailing.
Tags: Aiebrush
fox
    January 2007
Posted by fox on Thursday, August 13, 2015 12:00 PM
I can't answer your question but if you go to the Painting section of the Forums, someone there will be glad to help you.
Jim  Captain
 Main WIP:
    September 2006
Posted by the Baron on Thursday, August 13, 2015 12:06 PM
I'll second Fox, try the Painting forum.
You might want to fix your tag, too, it currently reads "aiebrush"
Posted by Tojo72 on Thursday, August 13, 2015 1:26 PM
Hello and welcome to the forums
    August 2015
Posted by Arved on Friday, August 14, 2015 8:25 AM
Welcome!
The answer, of course, is "it depends." Paint viscosity, air pressure, airbrush design and even air temperature and humidity all play a factor. Nothing beats going out and playing with the airbrush and your paints.
I suggest you "problem solve." How is your airbrush misbehaving? That will give us a better idea of what to recommend to try and solve the problem.
- Arved
e-mail | Blog
"Simplicate and Add Lightness" — design philosophy of Ed Heinemann, Douglas Aircraft
    March 2013
Posted by patrick206 on Monday, August 17, 2015 2:24 PM
A quick answer is:
For very sharply defined freehand borders, like camoflague, a fine needle/nozzle will allow close distance spraying with little overspray.
A medium set will produce a much softer border, with noticeable overspray dotting from larger paint droplets. This is useful for spraying where you have areas not to be painted masked, no concerns about over spray.
A large set I consider more useful for wide area coverage, like a primer, solid color or base coat.
I strongly recommend a look at "Don's Airbrush" website, it's a very well organized and detailed introduction to most everything about airbrushing, very well worth the time investment to gain more knowledge and insight. Guaranteed you'll learn lot's of useful information.
Patrick
    September 2003
Posted by checkmateking02 on Monday, August 17, 2015 7:01 PM
Welcome to the Forum!
    January 2013
Posted by BlackSheepTwoOneFour on Monday, August 17, 2015 9:12 PM
Please refer all questions to proper forum threads! This thread is for introductions, not model related questions.
