I have this bad boy about 2/3 complete. Had to do allot of work to get a decent fit of the wind screen area. Also there is a pretty significant step when the front nose section is joined to the main fuselage. Any body else run across this yet?
Welcome aboard. This is best posted in the Aircraft section, you will have more chance getting a decent response.
This is the intro section,welcome,post your question in aircraft.
Tojo72 This is the intro section,welcome,post your question in aircraft.
on a current build I ran into a "step" issue. Since it was along panel lines, I ended up using strip styrene to build up the low side, and faired that in with sanding. Finished off with Mr. Surfacer.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
