Hello and a question
    February 2019
Posted by jbruels on Saturday, February 16, 2019 10:23 PM
First venture into scale modeling in 45 years.  I'm struck with how much of an art it really is!  It can get a little overwheling how many different ways to do things there are.  Anyway, below is my first project.  I've messed it up pretty bad and I knew I would but I've learned a whole lot.  My current question is this:  There are some mismatches in the scaling of the model and the size of the decals.  There was also one error in numbering leading me to place and fix two decals in the wrong spot.  So, just like it's important to "test fit" plastic parts so I can trim and sand to make sure there are nice and flush, what's the best way to "test fit" decals and trim them as needed?
No photo description available.
fox
    January 2007
Posted by fox on Monday, February 18, 2019 4:10 PM
Welcome to the Forums! Glad to have you with us.
I'm not an expert by any stretch of the imagination but it looks like you did a pretty good job to me. My idea for checking size of decals is to check some research pics of the plane in question. Seeing how they fit on the real plane in reguards to their location near physical features and panel lines etc. should give you a rough idea of what size they should be. Then matching them up to the model will tell you whether you have a match or not.
If they don't fit, you have two choices. One is to check for aftermarket sheets for that particular plane. Second choice is to make your own. There are programs available to draw the ones you need and size them up or down to fit your needs. When finished, print them out. There are a few companies out there where you can get different color decal paper and it's not very expensive. Maybe you have a friend that can do it for you.  A member of our local club does mine when I need them.
Hopes that this helps a little. Looking forward to seeing how you make out.
Jim  Captain
 Main WIP:
    September 2012
Posted by GMorrison on Monday, February 18, 2019 4:29 PM
trust your eyeballs. You can certainly make a copy and test that on the kit to see if it "looks" right.
I scan all of my decals, and can print them on decals paper including setting the scale.
What's tough is finding what's "right" to compare to. The kit instructions may very well replicate any errors in the decals. And most photos are never straight on.
But you can look at enough photos to get a good idea of what the size should be. Purely hypothetical- the USAF on your jet starts at the inner end of the forward wing slat and ends at the outer end of the aileron. That kind of thing.
    June 2014
Posted by Tanker - Builder on Monday, February 18, 2019 5:57 PM
Hi;
 And welcome .I just use the old " eyeball mark one ".If it doesnt look right there  ,I change it .
    September 2003
Posted by checkmateking02 on Monday, February 18, 2019 8:42 PM
Good advice!  And welcome to the Forums!
    July 2018
Posted by Tickmagnet on Wednesday, February 20, 2019 9:35 AM
Nice looking build to me. I despise decals. Airbrush, stencil, paint as many of them as you can.
    December 2018
Posted by Tosh on Thursday, February 21, 2019 8:32 PM
Welcome to FSM Forums,
Your friend, Toshi
Reside in Streetsboro, Ohio
    July 2012
Posted by littletimmy on Friday, February 22, 2019 3:04 PM
Howdy !
She's a fine bird you got there !
jbruels
Trim as close to the decal "Carrier film" as you can, and test fit on the kit while the decal is still on the paper.
jbruels
No, you did just fine ......
THIS is what a "Messed up kit" look's like...
You may try as hard as you like... you will never match my "Botchkitomy" skill's !
Welcome to FSM.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    February 2019
Posted by jbruels on Thursday, March 7, 2019 7:53 PM
Thanks, everyone, for the tips! My next build is a B-58 by LIndberg. I'm not happy with the decals at all but found an aftermarket set at my local shop. They fit the bill perfectly! Now, if I can only find a way to craft an aerospike and that nifty 20mm autocannon in the tail. A crime this model came without those features!
