Hi guys
Hi guys
Posted by Anonymous on Saturday, November 25, 2006 11:10 AM
Im 32 yrs young and a HUGE WW2 buff.  Have been all my life.  Well I have always wanted to have plastic models WW2 style and would kinda like to see what I can do.  I always love running into te models that are put together at hobby shops or various other places.  I know that I would never be able to achieve that but would love to try!!
Anyways just a couple questions guy and gals.  I have NO artistic talent whatsoever! and what are my chances of my models turning out to be anything like the real thing.  I recently bought a generic airbrush off the bay and would like to know if I need to spend $100 on a compressor or can I go cheaper?  One last ?....  I think I am going to start with a nice B-17, what are some good kits?
Thanks for reading guys(sorry for the long read....I tend to ramble)
Scott
    August 2006
Posted by Gun Tech on Saturday, November 25, 2006 12:02 PM
Welcome to the forums Scott and enjoy!
Jean-Michel    "Arte et Marte"
Posted by jeaton01 on Saturday, November 25, 2006 6:31 PM
Revell made a 1/48 B-17F, Monogram has been a steady supplier of the B-17G in 1/48, kit 5600.  In 1/72 Academy has done almost all of the earlier B-17's, and Hasegawa has also done the G at least in 1/72.  Revell has also done one in 1/72, but it is a very old kit, not nearly as nice as the others that are newer.
You may want to start with a simpler project, the 4 motor bird can be complicated.  The 1/48 Tamiya F4F-4 is recognized as being very easy to put together, the parts fit very well and it is a very good replica using just the parts that come in the box.  The Tamiya P-47 kits are also well regarded in 1/48, and since you like WW II subjects might be to your liking.
Painting any kit is the steepest part of the learning curve, with filling and sanding to get rid of the seams being the next hardest part for me to get right.
As to the air compressor, the least expensive route is one of those made to pump up tires and available at K-Mart and so on.  As I remember they are battery powered or plug into a cigarette lighter (12 volt, use a small Gell Cel battery or motorcycle battery).  I use a 2HP shop compressor with a storage tank built, way overkill as an airbrush needs only 10-20 psi and not much volume.  The nicest are the ones made for airbrush work but they are expensive.  Most of all no matter what you use be sure and have a good pressure regulator and moisture trap, and filter your paints very well, maybe with an old nylon stocking.
 A success (your definition of it!) on your first model will trick you into staying with this hobby.  Much more fun than failure!  Good luck and enjoy.
John
Posted by rjkplasticmod on Saturday, November 25, 2006 6:37 PM
Welcome to the Forums Scott Sign - Welcome [#welcome].
Regards,  Rick
    March 2006
Posted by Dubau on Sunday, November 26, 2006 8:20 AM
Sign - Welcome [#welcome] Home
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
Posted by cassibill on Tuesday, November 28, 2006 12:07 PM
Hi, Scott.  Well what kit is best depends on what you want.  If you want to build up a large type collection (one of every type), you might want to think about going the 1/72 route.  The kits are cheaper, the selection is wider, they take up lest room, and if you wanted you could add armor to the collection.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
