Hi Smash
I know this is long but bear with me,over the years I have helped quite a few people get into this hobby ( I have been building for about 35 years now) and I have the following advice:
1: Use quality tools and a sharp knife. Knife blades are cheap, dull blades skip and usually wind up cutting you. Wear eye protection when using your shears to cut anything metal or that can fly way. Wet/ dry sandpaper in 220/320/400/600 grits plus some 000 steel wool are invaluable. I have clothespins that date back to when I was a kid, plus all sorts of hemostats, clamps, etc from various places (including radio shack). I like Tamiya liquid glue, but have used just about everything on the market avialable in the US. Putty is a subject in and of itself, a search of the forums here will find dozens of threads on that topic alone. HAVE FUN!
2: Building models is really about building and mastering tasks, primary assembly,basic seam fillling, mastering clear parts installation and finally mastering finishes and decals. Take each step a chunk at a time, learning as you go. I try to build for an hour or so a day. When you have got some experience with less expensive kits and feel comfortable moving on, then its time to get those pricey Acamiyagawa kits. Smaller kits may actually be a bit harder to build than larger (depending on what you are building) kits when you are starting out. For planes 1/48 is a great place to start. Autos are less "choosey" while ships can vary widely in price and size. The October 2006 issue of Finescale modeler has a good article on filling seams using a variety of techniques that I currrently use. Back in the '80's Finescale Modeler had a continuing series called BASIC TECHNIQUES<-->ADVANCED RESULTS that ran for some time, and was a fanstastic primer for many of us. HAVE FUN!
3: I used to help out with a class on Friday afternoons for anyone that wanted to learn, and we found that more people learned more skills with less expensive Revell/ Monogram kits (learning seam filling, learning proper alignment) than with "shake and bake" Tamiya and Hasegawa kits (throw in a bottle of glue, shake the box and you are done) . I find you won't gain as many skills in the long run by learning on these kits at first (I'ts like learning to fly by letting the autopilot fly the plane for you). HAVE FUN!
4:Don't worry about airbrushes at first. Work on the basics first and spend your dollars on kits and good tools, an airbrush will come in time. I have been airbrushing for twenty five years but I shot a motorcylcle with a spraycan yesterday (I build mainly helicopters and sci-fi, but break it up for variety). I have learned techniques and skills from Auto, Figure, Armor, Wargame miniature and SciFi guys, even tho I may have no interest in what they are building, there is something to be learned there. HAVE FUN!
5: Try to find a copy of the older book "building scale plastic models" It was an IPMS collaboration put out in the early 80s by Kalmbach Publishing, and while much of the material in it may look "dated" and perhaps even "antiquiated" at first, but I have gone back and re-read that book time and again. The basics have not changed over time and this is many perpsectives in one format. HAVE FUN!
6: The Shep Paine modeling books have been invaluable to me over the years even tho I do not build tanks. His insight into the state of the hobby in the 80s and late 70s, and how to make things on your own (there was no resin other than your own dental resin and PE was just on the horizon) has helped many established modelers over and over again. It's easy to drop a Aries,B/B or C/C resin set into a model, but far more satisfying to make something on your own. HAVE FUN!
7: Dont be afraid of being seen in the craft aisles . I have purchased so many useful things in the jewelry/beading aisle this past year it is not even funny. Be creative in solving problems. Beading wire is awesome and easily bent to shape. Motors stripped for wire last for years. Things you may think are junk (packaging inserts, broken parts, etc) may find some use in time, I have a organizer box of odd shaped parts, motor gears, etc. HAVE FUN!
8: Sometimes a little failure helps out in the long run. Dont let a percieved "failure" get you down for long. There are ways to fix just about any problem. Overcoming this is just one more skill you will add to your knowledge base. Just today I knocked the tip of an elf assassin's ear off of a 1/5 scale figure, and cannot find the chunk that came off. I am using epoxy putty to sculpt a rough shape of a new ear tip so I can file out the replacement. HAVE FUN!
9: If you have a local club, check into attending thier meetings--attendance will be free while membership will have some small fee. I hear this a LOT: "Nah, Im not up to the level of you experts!" I am NOT an expert! Experts get called onto the witness stand to testify in court. I do this as a hobby with a lower case "h" I just have a skillset that came with time and interest. Anyone that will not share thier knowledge, or considers anything they have to be "secrets" is a disgrace to this hobby in my not so humble opinion, and I steer well clear of them. HAVE FUN and meet people. Some clubs are more fun than others, but just because a club is small does not mean they are "boring"! Also, it is very important that as a new member you bring your models to the meeting--it sounds odd, but most new members do not bring what they are working on, so us old timers cannot see where we can provide guidance for them to gain that next skillset. HAVE FUN and bring your models!
10: The most important thing is to ENJOY what you do. It is for YOU to enjoy. It is your hobby, and dont ever let anyone tell you that you painted a Acamiyagawa Hestersnotz Mk XXXVII the wrong shade of pink!
Welcome to the hobby, I've had a lot of them and this is the one I have stuck with the longest. Check out my website for some step by step tutorials as well;
http://www.angelfire.com/ca4/hlmp/home.html
David
Build to please yourself, and don't worry about what others think!
TI 4019 Jolly Roger Squadron, 501st Legion
