ABS plastic
    September 2003
ABS plastic
Posted by TEEKAY on Thursday, September 16, 2010 12:29 PM
I would like to know if there is any special techniques that I need to use in working with ABS plastic.  Do I need a certain adhesive or will super glue and liquid cement work?  Is painting the ABS going to be a problem or can I use Model Master enamels and such.  Any help on this matter is greatly appreciated.
    August 2006
Posted by HawkeyeHobbies on Thursday, September 16, 2010 3:50 PM
As long as you use the right liquid solvent and properly prime before painting you shouldn't have any major issues.
Gerald "Hawkeye" Voigt
    March 2010
Posted by Scorpiomikey on Thursday, September 16, 2010 3:58 PM
What hawkeye said. Here at work we use a rubber compound to put ABS components together. Its horribly messy but it swells in contact with water which helps seal the pipes. And in terms of painting, we just use regular house paint lol. Thats not really any use to you. but i thought id mention it.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    August 2005
Posted by Phil_H on Thursday, September 16, 2010 7:08 PM
TEEKAY
Most regular cements for styrene models won't work with ABS. You may wish to see if your LHS carries Plastruct Plastic Weld cement, as this is formulated to work with ABS (some of Plastruct's products are ABS).
    July 2010
Posted by Mad-Modeler on Thursday, September 16, 2010 7:15 PM
Get thee to the hardware store, and ask for ABS glue(common used in plumbing).
ABS has a smoother surface than IP so many paints won't stick well, get a self-etching automotive primer and you are golden.
Have fun.
    September 2003
Posted by TEEKAY on Friday, September 17, 2010 12:29 PM
Thanks for the info.  I will give it a try.  Do you know if the ABS cement is compatiable with styrene?
    July 2010
Posted by Mad-Modeler on Friday, September 17, 2010 2:22 PM
ABS glue won't work on styrene. Sorry.
    October 2010
Posted by seglob on Sunday, October 3, 2010 3:29 AM
Earn an Extra $1000 to $1200 per month doing Part Time Data Entry Jobs! Work from home data entry jobs to post simple data submissions on Internet. Make $1 per entry. Easy form filling, data entry and ad posting jobs. No selling, No phone calls, No Marketing. No Investment. Bi-weekly payments. Full Training Provided. Pls visit: Data-Entry
