Slow Computer
    December 2013
Slow Computer
Posted by CodyJ on Wednesday, July 9, 2014 9:03 PM
I know this is a question that can be googled but I need this explained in simple terms.  I have a ASUS laptop that used to be a rocket.  It has quad-core, solid state HD, 5870 ATI Graphics Card, 8GB Ram, etc.  Now for some reason it just acts chocked up.  I have used CCleaner and that helped and so did running a Defrag and scan.  I also have most things I don't use uninstalled and all features I don't use turned off.  Still it wont play a simulator it used to very easily....  Its just acts like there is something sucking up juice in the background.  Anything I can check or try that you guys know of.  Thanks All!
    July 2013
Posted by DURR on Wednesday, July 9, 2014 9:08 PM
have you ever cleaned out the registry
    December 2013
Posted by CodyJ on Wednesday, July 9, 2014 9:10 PM
Yeah I think I did with CCleaner.  Its helped a good amount but still a ton slower than it has been in previous times.
    July 2013
Posted by DURR on Wednesday, July 9, 2014 9:16 PM
http://www.wisecleaner.com/wiseregistrycleanerfree.html    its free   down it   follow inst run it  and.......
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, July 9, 2014 11:35 PM
You may have a virus or malware that slowing down your laptop. When was the last time you did a antivirus program scan? Go to cnet.com and download Malwarebytes and see if that helps.
    September 2013
Posted by Les.61 on Wednesday, July 9, 2014 11:50 PM
There could be many things slowing it down, anti virus software, etc. The more programs added the slower they normally get. Even uninstalling programs will leave bits and pieces behind that can slow down computers. I have a friend who formats his hard drive and reinstalls all his software every 6 months but that is taking things to extremes. Try the 3 finger salute (Crtl - Alt - Del) and have a look in Task Manager to see what is running (assuming you are using Windows). Within the Task Manager also go to Performance and click on Resource Monitor and check what is using up your CPU, Memory and Disk.
    December 2013
Posted by CodyJ on Thursday, July 10, 2014 12:24 AM
Thanks Guys I'm trying your suggestions as I type (installing right now)!
Les.61-  Unfortunately when I look at whats eating up my CPU usage I don't know what should be being used or not.  Embarrassed
    December 2013
Posted by CodyJ on Thursday, July 10, 2014 12:32 AM
Hey thanks Guys!  I have never ran that Malwarebyte Program before and it found quite a bit!   Also ran the registry cleaner with CCleaner.  We will see how it performs here....
    May 2013
Posted by hogfanfs on Thursday, July 10, 2014 7:13 AM
If it's still slow, you may want to consider re-installing the O/S.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    June 2013
Posted by rjhansen26 on Thursday, July 10, 2014 11:49 AM
You may have some programs running in the background slowing things down. Hold down the key with the windows flag and press R, this will open the run window.  You can also find the run window under accessories under programs.  Type in msconfig and run it. Select the startup tab. This will show a list of programs that start and run in the background. You uncheck the box in front of an item to keep it from starting. You will recognize some that you will want to leave running, i.e. iTunes helper if you are using iTunes. If you don't recognize a program uncheck it, you can always come back and turn it back on if you break something you use. None of these programs are necessary for Windows to start up and run so you can't hurt anything by shutting these programs off.
Roger
"Life is short..........Always eat dessert first!"
    April 2005
Posted by ddp59 on Thursday, July 10, 2014 2:13 PM
rjhansen26, ccleaner can do the same thing by going into tools then startup.
CodyJ, what version of malwarebytes are you running as current version is 2.0.2.1012?
    December 2004
Posted by panzerpilot on Friday, July 11, 2014 5:51 PM
What OS is it? I still have windows XP on an old laptop and it has really gotten slower in recent months since they stopped updating.
-Tom
    April 2005
Posted by ddp59 on Friday, July 11, 2014 7:51 PM
the end of updates for xp has nothing to do with xp getting slow as most likely have some nasties in it or to many things in your startup.
