How to make binoculars wider?
    July 2008
Posted by castelnuovo on Sunday, May 8, 2022 11:16 PM
I got this binoculars for a gift but they can't open wide enough for me. Is there any way to make them open wider?
Thanks
Posted by gregbale on Monday, May 9, 2022 7:31 AM
Most binocs have a cylindrical 'hinge' between the two barrels, usually just a friction-lock that will pivot open with very little pressure applied. If yours lack this, i. e., if your barrels are fixed together rigidly, I'm afraid you're SOL.
 Cheers
Greg
George Lewis:
    October 2019
Posted by Tanker-Builder on Monday, May 9, 2022 8:41 AM
Hi;
       How Big are they? You will find that the Smaller Binocs are a unusual thing. There was back in my ChildHood(yeah,I had one of those too) Small Binoculars called (Opera Glasses). These were used in the V.I.P. Boxes to allow the (Uppercrust) To see the stage and performers Better.
       They were by definition Smaller specific use ("Extendable Glasses") For far viewing in an enclosed area. This may be what you got. The Larger Binoculars were used by the Navy and Army units for Surveillance Specifically. Then Hunters used and still use them to this day.
     What you can do. You can cut off the connectors, between Barrels rightat the barrels.Then take .080 Sheet and using the original part( stillattached) as a pattern, just elongate the part that connects to the Barrel. Or save your money and Buy your own that fits the width of your eyes!
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Monday, May 9, 2022 12:58 PM
You'll need two.
Put one lense on one eye and the other lense on the other eye.
     Then point in the same direction.......       :?
 https://i.imgur.com/LjRRaV1.png
    October 2004
Posted by ikar01 on Monday, May 9, 2022 3:23 PM
You forgot about the easy solution..just run over them with a truck and the lenses will seperate.
I never said it was a perfect solution, but then again I never really had any luck using them in the first place.
Posted by Tojo72 on Monday, May 9, 2022 5:37 PM
And I thought it was good that I didnt give any wise guy comments
    July 2008
Posted by castelnuovo on Monday, May 9, 2022 6:31 PM
I know about the hinge. They go as wide as possible but still a bit nerrow. I was hoping somebody in the know can have some mechanical solution, other then running over them in a truck Huh? or simillar unworkable "solution"
So maybe SOL
    March 2022
Posted by missileman2000 on Tuesday, May 10, 2022 9:09 AM
TB's solution is fine for those binoculars that have three different assemblies, with the hinge a seperate assembly. It is harder with the type (most common) where the hinge is built into each half and a long pin fitting through.    You need to make a plate at each end having three holes and have three pins.  Two do not need to be threaded, keep the original pin for the third, odd hole.  I personally would make those plates thicker, at least .125, and the holes in each plate need to be match drilled to assure proper alignment when assembled.  I'd make those plates in the form of an equalateral triangle, with the holes also equalateral.
    August 2019
Posted by HooYah Deep Sea on Saturday, May 21, 2022 10:48 AM
When most binos are opened fully, there is a little 'stop step' where the two sides make contact. With care, you could possibly grind away a little bit of the step, allowing the swing to increase enough to work for you. Some binos have only one stop step, while others have two (as in this set).
"Why do I do this? Because the money's good, the scenery changes and they let me use explosives, okay?"
    July 2008
Posted by castelnuovo on Saturday, May 21, 2022 5:28 PM
This sounds reasonable. Mine has 2 stop steps, one short and one that is almost as long as the the axel between the two hinges. I'll try grinding them down. They are made of hard plastic so it is I think, doable.
