Casting in resin
Casting in resin
Posted by Anonymous on Thursday, November 20, 2003 6:07 AM
Hi all,
I am thinking about doing some casting in resin and not having done any before so I am looking for some advice on whats good or bad, dos and donts. What I need is a resin that can be machined or drilled and can withstand some rough handling after its all set also something that will not take weeks to go off. Its for a one off piece of a large scale model Im building and will be made from a one hit (or possibly two if my luck hangs out) mould which brings me onto the question would I need some type of release agent applied to the mould?
Thanks Guys
Chris
Posted by Swanny on Thursday, November 20, 2003 8:47 AM
Bare Metal Foil offers all the supplys needed plus instructionals in how to...
http://www.bare-metal.com/
Posted by Anonymous on Sunday, November 30, 2003 7:38 PM
Hi.
There are no big secrets to mold making and casting.
First of all you will need to decide if you are going to make 1-part or 2-part mold. 1-part molds are the easiest and I do them constantly to make bases for Kits.
Best stuff I have found to make a box to make the mold in are LEGO bricks, yep, raid your tots toy-box.
What you will need:
non-drying Clay
vaseline
Silicon Rubber for mold making
Resin for casting
Rubber gloves
For both the Rubber and Resin try to get hold of stuff that mixes at a 1:1 ratio, easier that way and better results.
Next you will need to make a decision on Resin, they tend to come in different setting/curing times (faster = hotter) slower curing time also allows air bubbles to escape and thus get more into the fine detail areas.
There are a few sites online that detail the whole mold making and casting process or send me an e-mail and I can talk you through the trouble areas.
