Thought it might be a good idea for all you modelers to chime in and post a couple tips, suggestions, resources, etc. about what YOU do to maintain your hobby health. Do you keep a fire extinguisher nearby? yes; two actually, one on the main workbench, one on the attached garage where I keep the AB spraybooth Maybe you have a spraybooth. yes; I use mainly enamels. Also use it whem I "cut" putty with acetone-based nailpolish remover for seam filling. Or you switched from lacquers to latex. use enamels; if I need to touch up or paint small parts, I turn on a small fan that blows across the workbench. Do you have rubber gloves that work really well, or an incredibly comfortable respirator? latex gloves, ubt mostly to keep my fingerprints away from the paint :) yes to respirator and DO change the filter as needed How about any "work practices" that you use? Tell us about what works (or doesn't) for you. a "sharps" container for used blades googles that i use when cutting/bending PE always cut/slice away from me small fan blowing across the bench when using solutions all bottles clearly labelled. glues and thinners kept away, in the dark, at room temperature storage until use. read the MSRP of all solvents and "stuff" i use. xcto knives and other "pointythings" have a container for holding while not in use, avoid rolling off table bottle of whatever liquid (paint, glue, thinner) always farther than the model; your hand then wont be able to knock the bottle over when you move it towards you and/or the model. enough clean surface to work in a safe, slow and efficient way. "slow-mo" hands when working Yeah, Im anal compulsive, spent 25 years working in biomedical research labs ;) This has the potential to help a lot of our fellow hobbyists. Thanks! Gip Winecoff |
