Gap filling materials
    February 2010
Posted by ozzman on Sunday, April 18, 2010 7:22 PM
Hey guys, I am making an aircraft, and found several gaps that need to be filled, I'm not too excited about using superglue, but white glue doesn't seem to work. Can anyone recommend materials with gap filling properties that I can find at a hobby shop or an arts and crafts store?
    September 2007
Posted by SuppressionFire on Sunday, April 18, 2010 7:32 PM
Tamiya filler putty drys fast and can be wiped off quickly with Acetone (nail polish remover) without effecting plastic details. Wet a Q-tip to wipe excess off from around hard to sand areas like wing roots.Yes
It can be thinned with liquid plastic solvent cement but will take a long time to cure for sanding. Thinning it in this way allows it to 'bite' the plastic better but be cautious as the solvent cement will soften plastic and mar details.
Some use automotive scratch filler putty which has similar properties. Get the kind in a tube not can. Its usually a red-oxide color and a better value per volume. I would only go this way if a hobby shop is unavailable.Hmm
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    December 2009
Posted by Harshman II on Sunday, April 18, 2010 7:50 PM
You can try toothpaste for small gaps if sanding can't get rid of it. Metal polisher paste works too
    June 2008
Posted by Hans von Hammer on Monday, April 19, 2010 8:41 AM
Personally, I use only Testor's white (Hobby Shop, thin with rubbing alcohol) or Bondo Red Glazing (Automotive parts shop, thin with Testor's Liquid Cement) for putties... Superglue, white glue, stretched spue, and styrene strip round out my other materials... There's really no "one and only" gap-filler out there, IMHO...
Some kits require the use of all of them, lol...
    June 2009
Posted by redshft1920 on Friday, April 30, 2010 10:55 PM
Glad I stumbled across this message thread....I see the "Zap-a-Gap" stuff everywhere, but why are there so many different "flavors", i.e. pink, green, gold labels, fast cure; slo-cure....who can take this crazy bunch of snakes and lay 'em out straight? There's enough of these to need a manual just to see what each does and doesn't do well.
I tried Tamiya with the tiny green tube for mixing with the huge tube of putty (50:1 ratio, I think) but that was a waste of money. I'm not a good mix-n-fill guy I guess.....I do use Testors and it works fairly well for most of my needs, but I also bought a tube of Green Putty, too. That seems to dry super quick giving me little time to work with it before it starts leaving "cracks" in the surface which then need RE-puttying.
TOUGH subject to master, thus far anyway........
Bob
Van Buren, AR
Bob Moody in Cedarville AR
