Got Wood?
    October 2008
Got Wood?
Posted by Lacquer Head on Monday, May 17, 2010 7:24 PM
While looking at pictures of peoples workbenches, I noticed that some like to model on a small piece of wood. Is this better than say a self healing mat? For the people that use wood, why do you use it?
"Lacquer Head feeds his one desire, Lacquer Head sets his brain on fire."
Posted by Don Stauffer on Thursday, May 20, 2010 3:29 PM
Not sure, but this may be a holdover for folks who started building flying models- the stick and tissue kind, where one "pins down" the framework of balsa sticks.  One needs a working surface that is easy to stick pins into.  Personally, I have a three foot by one foot piece of particle board with one foot square cork tiles glued to it for when I build that kind of model.  My regular building surface is particle board with contact paper over it so I can "renew" it periodically.
Posted by Anonymous on Thursday, May 20, 2010 3:42 PM
What you are probably seeing is a "presentation" stand for taking pics of WIPS...like wildbill76 uses...
    March 2007
Posted by bondoman on Thursday, May 20, 2010 4:29 PM
I don't use wood because it's too soft to cut on. Particle board would be harder. I use mats.
Dre
    June 2007
Posted by Dre on Friday, May 21, 2010 10:24 AM
I work on a wood table that is not quite a butcher block-type deal but still thick and sturdy, but I don't use it as a cutting surface.   When paint is involved, I'll throw a piece of scrap cardboard down to work on.
    October 2008
Posted by Lacquer Head on Friday, May 21, 2010 1:55 PM
Thanks for the info guys.
    October 2008
Posted by Lacquer Head on Friday, May 21, 2010 2:15 PM
Posted by Jim Barton on Friday, May 21, 2010 6:04 PM
My workbench is an old plywood board atop a long narrow bookcase-like piece of furniture. On the plywood, I laid a heavy plastic advertising poster for bare-root rose bushes face-down (the back side is white). The inevitable little spills of paint, glue and so on don't bother it. When it's time to cut, I grab a small flat piece of clear plastic that I use as a cutting board, plus under the cutting board, I'll slip a small piece of box cardboard if the part I'm cutting is white.
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
Posted by tigerman on Friday, May 21, 2010 6:26 PM
I'm not touching this headline for fear of being banned. LOL Big Smile
 Eric
    May 2004
Posted by KINGTHAD on Monday, May 31, 2010 1:54 PM
I work on a sheet of glass luv it....and easy clean up.
Thad
