That Swordfish made me sick!!
Posted by arnie on Wednesday, June 2, 2010 10:31 AM
Does anyone else get "sick" of a model during a build?  I'm currently working on a Tamiya Swordfish. I've painted, decaled and rigged it and am about to start on the engine detailing but I can hardly stand to look at it right now.  I just want to put it all back in the box and go on to something else.
Does this happen to you too?
"There is a fine line between 'hobby' and 'mental illness'."---- Dave Barry
"Giggity"      -------------------------------------------------------------       Glenn Quagmire
Posted by Tojo72 on Wednesday, June 2, 2010 10:35 AM
for sure !! every so often a kit will end up in the garbage or the spare parts bin.
    September 2005
Posted by Sprue-ce Goose on Wednesday, June 2, 2010 11:32 AM
Wasn't the Daisy Red Ryder invented for just such a problem?
But seriously:  happens to everyone, that's why you see sooo many kits listed in progress.....
    June 2008
Posted by Hans von Hammer on Wednesday, June 2, 2010 2:09 PM
Got about 25 I'm sick of working on...
Posted by VanceCrozier on Wednesday, June 2, 2010 2:22 PM
...you mean today, or in the last year!! Yup, it happens. My most recent kit was Tamiya's 1/48th Fieseler Storch. There were several evenings that I just HAD to put it aside & I pulled out a little 1/72 kit just to see myself make progress on something!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    February 2010
Posted by ozzman on Friday, June 4, 2010 7:52 PM
yeah i was building a spitfire, and the same thing happened to me
    December 2009
Posted by Harshman II on Friday, June 4, 2010 8:02 PM
The more I build I more I am enuthsiastic...
If I got a bad kit. I will try to finish it off as soon as possible.
Never waste a kit!
    March 2007
Posted by bondoman on Sunday, June 6, 2010 1:14 AM
Tamiya swordfish makes you sick? What's the world coming to?
Put it on the shelf and realize that you'll be back to build it, when you have the patience.
    November 2008
Posted by iraqiwildman on Wednesday, June 9, 2010 10:40 AM
July 4th is coming up. Gets some bottle rockets and tape them to the wings and see if it flies.
My mom used to get so made that I would build a plane then blow them up in the sandbox. Oh the good old days.
Tim Wilding
    July 2008
Posted by Railfan 233 on Wednesday, June 9, 2010 7:06 PM
I get that with every kit I do (even free paper models).
I have found a cheep-effective, and non-destructive methood (Put the Dasy Red-Ryder Down!)
Just put the kit back in the box (or in a box, if it won't fit) and then start working on another kit. Once you get sick of the new kit, go back to the first one, and repeat untill both kits are done. Now I'm cranking completed kits out fast enough to warrent a monthly trip to the hobby shop (yet mom won't let me)
 ***NOTE: It won't work for restoring an old car. Once you get one, your stuck with it once you tear into it. After you remove the body, it will be immoble unless you own a flat bed truck (even then, it will be stuck on the truck, so you'll have to do all work on the back of the truck)
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpgRed, White, and YOU! group build of 2010
    March 2005
Posted by mfsob on Thursday, June 10, 2010 10:40 AM
I think the same thing happens to all of us at times. I label it the SOTS syndrome ... Sick Of This S*** ... which for me usually comes at an onerous stage like rigging the cargo booms on a 1/700 cargo booms or a 1/72 biplane (where I am currently with my Sopwith Camel).
And I do the same thing - put it in a box for awhile and forget about it. Then take it out and it's almost like starting over! The only refinement I add is that, with advancing senility, I leave a note about what paints I was using for specific parts, where I left off with specific steps, etc. Otherwise I might never, ever, remember.
    November 2003
Posted by Mike F6F on Saturday, June 12, 2010 3:28 PM
I've trashed a couple over the last few years because it seemed the Fates just decided those particular projects would be doomed.
Stuff would happen.
Seats would work loose in an enclosed cockpit after everything was sealed up an no longer accessible.
A bizarre juggling act would ensue while I was painting a base coat.  Everything would be fine, normal and I'd get hit with a spaz attack, dropping the wet model.
After sanding, cleaning up the mess, etc., and getting everything back on track, the decals would fracture.
Thank goodness, it doesn't happen often.
"Grumman on a Navy Airplane is like Sterling on Silver."
