German Pionier Rubber Raft
    June 2010
Posted by redenton on Monday, June 7, 2010 9:20 PM
I am wanting to do a diorama of the Grossdeutschland Infantry Regiment crossing a river in 1940 France. The only rubber assault boats I can find are the three man boats. Does anyone know if there is the larger version used to transport troops and equipment? I was about twice the size of the three man boat and basically the same style.
Roy Denton
"Nathamh na hoibre an t-eolas"
(Knowledge comes through practice)
    June 2008
Posted by Hans von Hammer on Tuesday, June 8, 2010 11:42 AM
Think you're gonna be stuck with scratchbuilding that item... You can use the three-man raft as a guide to enlarge it and use Sculpy or something similar to make the larger raft...
    June 2010
Posted by redenton on Wednesday, June 9, 2010 12:36 PM
Never tried that before, I've been out of the hobby for almost twenty years.
Roy Denton
    June 2010
Posted by redenton on Wednesday, June 9, 2010 12:43 PM
Okay persistence pays off. I found what I am looking for at Verlinden as an accessory of all things. It is the 1/35 scale German Supply Rubber Boat
This is actually the Medium Pneumatic Boat of the German pioniers, just what I was looking for.
Roy Denton
    June 2008
Posted by Hans von Hammer on Friday, June 11, 2010 6:14 AM
I stand corrected.. Good find..
    September 2007
Posted by SuppressionFire on Friday, June 11, 2010 7:28 AM
What would be cooler is if the tube actually inflated like the real one, that way weight in the center with the ends curled up would be... real! I always thought a diorama of a raft bridge would be cool to model. The footage of tanks & trucks crossing really shows weight as the rafts under the vehicle curl up, also only 1 vehicle at a time!
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    June 2008
Posted by Hans von Hammer on Friday, June 11, 2010 1:34 PM
Take a helluva lotta weight to bend an inflatable raft in scale... You can't scale down air pressure...
    July 2004
Posted by stikpusher on Friday, June 11, 2010 10:14 PM
Dragon also makes or has made a three man raft w/figures
and a large dinghy
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2010
Posted by redenton on Saturday, June 12, 2010 6:11 AM
Thanks, I saw these after I made the above post. Kind of cool they used the German nomenclature in parentheses. Although the Grosser Flosssack 34 (Large Pneumatic Boat 34) is actually the medium one. The small was 3.5m long, the medium 5.5m, and the large around 7.5m IIRC.
BTW my interest in these and other Pionier related models is that I served as an Engineer in the Army for 20 years. My Military Occupation Skill (MOS) was as a 12C which is the military bridging engineer.
As for the floats bending, the ones we used during WWII and even while I served had stiffeners along their length to reduce the effect significantly, otherwise the straps holding the two float halves together would fail and the entire ponton would separate and threaten the bridges stability
The Germans also stiffened their pneumatic boats with wooden floor boards to assist in maintaining rigidity. In addition when making rafts or bridges to carry equipment, they did their best, prescribed in their regulations, to cover close to two-thirds of the boats width with decking material. This leaves room in the ends for the engineers and their equipment. Rowers would sit around the edges of the deck to propel the raft.
Now if I could only find models of the 'B' material and 'D' material bridges. After all, one company has distributed a model of the Bailey Bridge used by the British and Americans.
Thanks for the above comments and sorry for the above lesson.
Roy Denton
    September 2007
Posted by SuppressionFire on Saturday, June 12, 2010 6:41 AM
Hans von Hammer
Indeed,
Less pressure could be added, like how your car tire looses 30% air pressure before its visually noticeable. Or build the diorama using Tamiya 1/48 scale armor with metal hullsHmm
    June 2008
Posted by Hans von Hammer on Saturday, June 12, 2010 11:45 AM
I'd heat-form it...
    July 2004
Posted by stikpusher on Saturday, June 12, 2010 12:36 PM
redenton
It's always good to learn about other MOSs in my book. I think the engineers are least appreciated and understood among those out there of the combat arms.
I dont know if this kit is the B or D type, but have you see it?
http://www.dragon-models.com/catalog/dml/new/6532/6532-poster.htm
       - Plankton
LSM
    June 2010
Posted by redenton on Saturday, June 12, 2010 1:29 PM
That is a improvised foot bridge using the small pneumatic boats.
The following page shows the B-type in the upper picture and the K-type in the top half of the middle picture. The text kind of describes both types.
http://www.warandgame.info/2008_02_17_archive.html
While looking for this information I ran across a site advertising the B-type in 1/35 scale. It has a raft, part of the bridge, the ramp end using trestles, and the various trailer loads required to transport the components. All of this is towards the bottom of the page.
http://www.scalelink.co.uk/acatalog/elite_models___militarmodellbau_____retail_only_.html
Roy Denton
