Applying Zimmerit
    August 2010
Applying Zimmerit
Posted by Furyan on Monday, August 9, 2010 8:18 PM
Hi
Im new here and before I start Id like to say great site!!  Looks awesome and I can see myself spending a bit of time here. Thank you.
I was linked here by a fellow forum friend in my country as Im building a 1/25 scale Tiger I tank of the Tamiya brand.
Its a brilliant model but Id like some hints or tips for applying the paste to make the German WW2 Zimmerit effect. Im using Tamiya's basic tubed putty, which seems ok but Im new to this application.
Any tips from anyone that is a gun at this would be great. Thanks again.
The pitures are located here > http://www.gpforums.co.nz/showthread.php?s=&threadid=396737
Last build: Tamiya's P-51D Mustang in big 1/32 - Lt Col J C Meyer and his blue nosed bastards. Never forgotten.
    August 2005
Posted by Phil_H on Monday, August 9, 2010 8:34 PM
Tamiya's 1/25 Tiger is an "early" and doesn't need Zim (of course you can put it on if you want, but it wouldn't be incorrect without it).
    August 2010
Posted by Furyan on Monday, August 9, 2010 8:41 PM
Yeah thanks. Its not the earliest of the early, looking through books on the topic even some of the relatively early ones had it applied.
I just reckon they look better with it.
    May 2008
Posted by Boba Fett on Tuesday, August 10, 2010 7:34 PM
Tere are so many methods... Resin zim, milliput, aves apoxie sculpt, I've even been experimenting with bondo. It's whatever you feel comfortable with. EXPERIMENT!!! That's the answer.
    September 2006
Posted by the Baron on Thursday, August 12, 2010 11:42 AM
I'll repeat a tip from the master himself, Shep Paine, as explained in the old "Tips on Building Dioramas" brochures in Monogram's armor kits.  His tip was to use a razor saw to make the lines.  I think that he was using spackle as the medium, back in the day, but for whatever putty that you use, the saw works well.  You drag the tip through the putty to make the verticle seams, and, holding the saw blade vertically, drag the teeth horizontally across the putty, to make those seams.  You just need to choose a blade with teeth spaced appropriately for the height of the rows.
Hope that helps!
    May 2008
Posted by Boba Fett on Thursday, August 12, 2010 2:45 PM
Hmmm... I didn't think of that. Thanks baron! And since spackle will flake and chip easily... You might want to rough up the hull where it is to be applied with low-grit paper if using spackle. It needs some "tooth" to hold to plastic.
    August 2010
Posted by Furyan on Thursday, August 12, 2010 3:44 PM
I use this meine friends Smile
Though it 1/35 and the tanks 1/25 I simply wait a tad longer for the putty to harden now and it draws thicker lines, its pretty spot on and a great tool.
    September 2006
Posted by the Baron on Friday, August 13, 2010 11:56 AM
I also have seen another, unusual method for replicating Zimmerit, and that was to use a pyrogravure tool or a soldering iron.  I have a Nichimo King Tiger in 1/35, that I got in my club's raffle.  Somebody had started the kit, and used the pyrogravure to burn in small rectangles.  It's not as crazy as it sounds, and doesn't look too bad.  I figured that I will go over the relief with Mr Surfacer, or maybe my homemade Mr Surfacer (Squadron putty thinned with acetone) to soften it a bit.  I'll take a pic and post it later, to show you what it looks like.
Best regards,
Brad
