clear plastic brittleness any way to make it stronger
    March 2010
Posted by ACESES5 on Tuesday, November 2, 2010 8:19 PM
Why are clear parts so brittle broke 2 canopiesAngry this afternoon for my fw190 any way they can be made stronger ?           ACESES5Bang Head
    December 2003
Posted by hkshooter on Tuesday, November 2, 2010 8:35 PM
Sorry, but no. You'll have to adjust the way you handle them.
Do you need a replacement canopy for the 190? What do you have? I am working on a 1/48 Tamiya dora and have a flat canopy I'm not going to use, if it will help.
    March 2005
Posted by mfsob on Tuesday, November 2, 2010 8:37 PM
It doesn't necessarily make them stronger, but I have found that coating clear parts with Future prior to cutting them from the sprue seems to reduce the tendency for cracking and spalling.
    August 2005
Posted by Phil_H on Tuesday, November 2, 2010 9:12 PM
ACESES5
Generally speaking, clear styrene is more brittle than coloured styrene because the clear styrene does not contain any filler material (and perhaps plasticisers) which make it more resilient.
    March 2010
Posted by ACESES5 on Tuesday, November 2, 2010 9:30 PM
hkshooter: Thanks for the offer I had a spare in my parts box left from a hasagawa kit used it and thanks for info guys,I'll just have to be a little more gentle.             ACESES5Bow DownBow DownBow Down
    August 2008
Posted by tankerbuilder on Thursday, November 4, 2010 7:32 AM
HI; I do believe you have stumbled into a problem most aircraft builders have had at one time or another.I don,t do that many, but, if its a very special (to me) a/c then when I buy it i go to the vendors list in FSM and buy the vacuformed replacement.These parts are made from a different plastic and are very flexible as well as very thin" SCALE THICKNESS" almost.Give it a try on your next one and I sure am glad you had a spare. tankerbuilder
    March 2010
Posted by ACESES5 on Thursday, November 4, 2010 12:00 PM
tankerbuilder: Thanks I've wanting to try that next plane build I'll give it a try.             ACESES5                                               ON BENCH PANZER IV AUSF D "VORPANZER CYBER 1/35Bow Down
