What Brand/type of glue for PE? CA Not working
    December 2009
Posted by jseese on Tuesday, December 21, 2010 7:30 AM
What glue does everyone used for PE? (Brand and number is possible) Everything I researched says use CA or white glue. The problem I have with CA is it drys and then with any little pressure or seems if I look at it wrong, lol, the glued parts just break off right at the joint. The glue comes off clean and dry like it isn't strong enough to hold the seam. I have been using a pink label ZAP product and also tried a "generic" pink label CA from Hobby Lobby. I really like working with PE to get the fine details but attaching them is driving me crazy!!!! Any tips or tricks?
Jon
Posted by VanceCrozier on Tuesday, December 21, 2010 8:05 AM
I've been using Zap-a-gap's CA, both thin and gap-filling versions with no problems. CA just doesn't behave like the "welder" type glues for plastic, those actually melt the plastic from the two parts into each other. CA behaves just like you described - it'll glue anything to anything, but if you push the pieces in the right direction, they will pop off & leave flaky dried glue behind. I also try to seal it up afterward with a coat of Future or dullcoat to help strengthen the bond.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2009
Posted by Kentucky Colonel on Tuesday, December 21, 2010 8:18 AM
http://www.gatorsmask.com/gatorglueorder.html
I used to use CA but started to have the same problems you posted. I tried this and once it drys everything stays on, in fact it's flixable. I found that out by mistake when I picked up a finished model wrong and I thought for sure I had ruined the PE but once I took my hand off the PE parts went back into place where they were guled on. Any other gule would have broken off and I would have to re-gule them on.
One problem. the Gator Gule FREEZES so if you live in the cold states you better wait until spring to order since it will freeze in the mail.
While writting this I reached over and picked up my Dragon 1/350 USS Buchanan and I'm holding the whole model up by part of the PE rails, the rails are not coming off.
    September 2008
Posted by maxfax on Tuesday, December 21, 2010 8:26 AM
Kentucky: Man, that sounds like one strong glue. I'll have to try it.
On the bench:  Revell 1/72 HCMS Snowberry
    October 2009
Posted by Kentucky Colonel on Tuesday, December 21, 2010 8:48 AM
It is. I've been using it about a year and so far no problems. It's white but drys clear and another great thing about it is you can wash the brush you use to apply the glue off with water when you are though.
You can also order these
http://www.gatorsmask.com/applicators.html
They are perefct for neat applications and once you are though you wash the applicators and needles out with warm soapy water, they will be ready to go the next time you need them.
Posted by VanceCrozier on Tuesday, December 21, 2010 8:55 AM
I've never tried the stuff, will have to wait until the spring thaw to order some though!!
    December 2009
Posted by jseese on Tuesday, December 21, 2010 10:31 AM
That gator stuff sounds strong!! I am in WI so it may be awhile before i could have it mailed. I can't belive it is so strong that you can pick up a model by a railing. I have such a hard time paininting because I have to be so fragile with the model because of any etch details.
    November 2008
Posted by iraqiwildman on Tuesday, December 21, 2010 11:01 AM
I think I have seen this glue at Hobby Lobby. I will be there later today getting some primer, so I am going to check this out. I really like that applicator. CA is such a hassle trying to use a toothpick or think brass wire to apply.
Tim Wilding
    March 2010
Posted by shoot&scoot on Tuesday, December 21, 2010 11:49 AM
Haven't tried the Gator stuff but it looks interesting.  Been using Gorrilla brand CA with no problems.  It seems to have an added ingredient that allows for a little flexibillity making it harder to break off small pieces.
I've noticed over the last year or so some PE has an oily finish to it so have been using mild detergent and water to clean it off.  I have gotten better glue joints since doing this.
        Pat.
    December 2003
Posted by hkshooter on Tuesday, December 21, 2010 3:01 PM
I ordered some of that gator glue today. If it freezes then so will it thaw. The website never indicated there were negative affects of the freezing.
    December 2009
Posted by jseese on Tuesday, December 21, 2010 3:26 PM
I emailed them and he said if they know it is going to colder climates they wrap the bottle in insulation and take measures to keep it from freezing. He said he hasn't had a complaint yet on a frozen product. I will be ordering some today as well.
    March 2005
Posted by mfsob on Friday, December 24, 2010 11:00 AM
A couple of issues here. 1) Most PE frets have some kind of releasing or finishing agent on them, so they need to be cleaned. That also helps to give them "tooth" so the paint sticks well. I always give mine a bath in plain old white vinegar (5% acidity) to remove anything on the frets and to mildly etch them, then a good rinsing in cool water and thorough air drying.
2) CA glues, as many of you have discovered, are great for holding things together as long as no lateral strain is put on the parts after joining them (which makes it great for 1/700 ship railings and such). You MAY have better luck with the gel-type CA glues, which is what I use since they also have slower drying times, and they tend to fill in any irregularities between the two bonding surfaces to give a tighter overall bond. I use Pacer Sheet Zap, PT-30, in the blue bottle. It's actually intended for the R/C crowd but I need that extra few seconds of working time. I've never had problems with parts popping off or seperating after using this stuff, quite the contrary ... there are times when I wish I could get them to separate after experiencing one of those " Oh Censored!" moments we all have right after we have glued the wrong parts together.
    August 2005
Posted by Phil_H on Saturday, December 25, 2010 11:54 PM
As has been mentioned above, CA glues have good tensile strength but have very poor shear strength.
Another key to good bonds with CA is surface area. If the two surfaces being glued do not have much contact area, then there's no way you will get a good bond. Take two rounded pieces of sprue and try to glue them together one across the other. It's nearly impossible to get it to hold regardless of how much glue you put on the joint. Sand or file a small flat on each piece and use a tiny drop of glue - you will find that it holds up very well.
