looking for clear sheet plastic
Posted by Anonymous on Sunday, January 18, 2004 10:44 PM
Hey guys, I'm trying to find some VERY thin clear sheet plastic to use for something on a model I'm working on. I've seen tons of thin sheet stock in white, but never clear. Any idea where I might find some?
thanks in advance
Posted by Anonymous on Sunday, January 18, 2004 11:05 PM
Plastruct, Evergreen and Tamiya(Pla-Paper)make some, but I am sure there are more companies producing.
I use them a lot for making dial faces and similar.
Thinnest I have used is 0.2mm but they come in different thicknesses.
They are also nice for vac-molding new canopies and similar.
Check your LHS, Arts Supply and local Model Railroad Stores for architectural model supplies.
Posted by Anonymous on Monday, January 19, 2004 12:09 AM
I think Micro Mark sells it, and also squadron.
www.micromark.com
www.squadron.com
Posted by Anonymous on Monday, January 19, 2004 12:42 PM
If you can't find or don't wish to purchase clear sheet as suggested above, you could use the center sections of the clear plastic tops to the aluminum trays that many Chinese take-out restaurants use. In addition, take a brouse through your local super market. You will be surprised at how much of the packaging use these clear flat thin tops. I've even used some of this stuff for vacuum forming new canopies. Wink [;)]
Pete
Posted by wayne baker on Monday, January 19, 2004 1:31 PM
Squadron sells a clear they suggest using for thermoformed canopies.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by Anonymous on Monday, January 19, 2004 5:23 PM
I have used the clear plastic from "bubble" packages and pasta boxes to make reflector gunsights for 1/48 aircraft. If you need a certain shape, check out the packaging on some products in the supermarket or pharmacy. Might have something there you're looking for.
