fixing a deformed wing
    March 2011
Posted by pdsquirrel on Friday, March 4, 2011 2:20 AM
I have just started back modeling after about 10 years. So I pull out a 1/72 scale f-14 tomcat and started to get back into building. I found that one of the wings is deformed and I need to find a way to bend it so it looks normal. Anyone have any ideas on how to go about doing it?. Any help would be appreciated.
Richard
Posted by Don Stauffer on Friday, March 4, 2011 8:58 AM
You might get more replies if you post this in the aircraft forum.  You do not indicate exactly how the wing is deformed, but in some cases putting in a wooden spar can solve some deformation problems.
Posted by VanceCrozier on Friday, March 4, 2011 9:11 AM
The first thing I try in that case is immersing the wing in hot (not boiling) water for a few minutes, until the plastic becomes a little more flexible. Twist or bend the wing a little bit past the point that would straighten it out. Then immerse the wing in cold water for a few minutes. This is usually pretty successful on small thin sections like an aircraft wing.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2011
Posted by pdsquirrel on Tuesday, March 8, 2011 3:08 AM
Ok, thank you both, and I will try both.
    January 2009
Posted by paintsniffer on Tuesday, March 8, 2011 12:37 PM
If it is warped I use clamps, a jig, and a hair dryer. It worked for me a few times.
Excuse me.. Is that an Uzi?
