Even with Desert Storm colors, nothing was ever standardized. I've played with variations of Desert Sand/Gulf War Sand (Testors) and mixing FS colors.
But let me give you my sense of perspective on this.
20 years ago I deployed to the Gulf as part of the 2nd Armored Cavalry Regiment. And one of the first things we did when our armor arrived was to paint them in Desert colors. With CARC (Chemical Agent Resistant Coating), which was designed to prevent chemical agents from bonding to our existing paint.
Now a word about the painting procedure. It was more than just painting over the woodland camouflage. First, the whole vehicle was coated in zinc phosphate. Then, a primer was put on and left to dry. The CARC was then sprayed (or rollered on). The actual procedure would have reminded you of the various color schemes of ME-109’s in the field. How’s it look, Ernst? Looks good to me, Hauptmann.
There were many variations of color during Desert Storm. What was dark tan for 3 ID was different from the pinkish tan of the 4/2 helicopters. Depending on the mixture, procedure followed (sometimes no primer was used) and underlying colors, it could vary in color quite a bit, even in vehicles of the same battalion.
With that in mind, don’t stress to much about whether the color is “accurate.”
There is one other thing that occurred in the desert that should help relieve your PMRS.
Many of the vehicles were painted in Al Jubayl, the Saudi port where our VII Corps off-loaded. The 325th Maintenance did a lot of the painting work, mostly with sprayers who wore respirators, and operated a high-tech painting rack.
But our Regiment had already moved out into the desert in order to provide screening for the rest of VII Corps. When it came time to paint our armor, we had to use local contractors for our 300 tanks and IFV’s.
As a young and cautious Captain, I watched the whole thing from upwind. Our contractor wanted to make it like a car wash. He built this metal contraption with sprayers on three sides. All we had to do was button up the driver and have him follow radio instructions as he moved forward. (All glass was taped up so he couldn’t see.)
However, in actual use the CARC clogged up the sprayers pretty quickly. So it was necessary to put civilians to work and spray the armor by hand, and sometimes with brushes and rollers.
None of the Saudi’s wore masks. There weren’t any available. After awhile, some of them started spitting up blood. They would be pulled off the line, and replaced with new people. Others would start hacking and coughing up mucous. They were not removed from the line until their work became uneven.
After a week, we had all the vehicles painted. We’ll never know how many Saudi’s suffered debilitating illness because of it.
So the next time you have problems with a clogged nozzle, or your tan isn’t quite the right shade, remember what it took to paint the armor in the field.
Oh, and use a paint booth. And maybe a mask.
