Re-scibing panel lines
    July 2011
Posted by SmartGambler on Thursday, July 14, 2011 7:53 PM
any tips for re-scribing panels lines when i glue 2 halves a fusalage together and have to fill the seam with white putty of mr surfacer i have trouble re-scribing the panel line over the seam filled area i have a tamiya panel line scriber tool and have tried using hasagawa trytool straight edges. The problem is the filler i used does not re-scibe well at all  any ideas
    May 2011
Posted by AceHawkDriver on Thursday, July 14, 2011 8:30 PM
it may be too far along now, without seeing what you're looking at, but i've found that using a plastic weld like tenax, ambroid pro weld, tamiya cement works best if you have to rescribe over a seam.  I haven't tried using the welds that i mentioned AFTER using (potentially since I don't know what you used) something else like CA.
it might be worth trying running some of the plastic weld along the join to soften the plastic, sand it smooth, and then try rescribing.  since you've used fill you'll have to find a way to remove it  first.  what you can use to remove it depends on the brand though.  EX:  squadron green will smooth over and can be removed a little at a time with nail polish remover.
Peace through superior firepower.
Brian
    January 2003
Posted by TomZ2 on Thursday, July 14, 2011 8:41 PM
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    July 2011
Posted by SmartGambler on Friday, July 15, 2011 8:37 AM
thanks i have been using these ideas and was hoping to find a more uniform way of doing it even then things i seen on the link left imperfect lines i guess iam shooting for the moon
    November 2004
Posted by Bronto on Friday, July 15, 2011 7:39 PM
SmartGambler
It just takes a lot of practice to be able to do is consistently.  You have to use less pressure when you get to where you have the filler than you were using on the plastic, or the filler will chip or cause what you are using to scribe to wander.  Also try using a pin or sewing needle to scribe instead of the commercially made "scribers".
    July 2011
Posted by SmartGambler on Saturday, July 16, 2011 7:19 AM
Thanks alot that worked better then anything i ever tried. the pin with light pressure worked perfect also i cut the dymo tape in very thin strips to help with the arc in the fusealage. this why i come to this site for great tips like this one just another tool in my modeling drawer.
    July 2007
Posted by troublemaker66 on Sunday, July 17, 2011 2:47 PM
SmartGambler
I guess we`ll have to re-name you "SmartModeler" now...won`t we?
Len Pytlewski
