Styrene or Resin: How To Tell The Difference?
    September 2005
Posted by Sprue-ce Goose on Saturday, October 8, 2011 8:02 PM
I just purchased some Halloween skull decorations from Michaels as same scale additions for my Rommel's Rod kits.
The parts are molded in a white substance; a different color from the usual resin accessories created for models.
Before I begin removing paint and sawing / separating the skulls from the molded displays I can't help but consider if the items are Styrene or resin- if for no other reason than safety..
How do I determine the difference ?
For instance: resin parts are normally glued using CA, what -if anything can I use as a test - that  dissolves resin but might not harm styrene?
Or am I better off just trying styrene glue on the objects and presume they are resin if not softened or dissolved?
    January 2006
Posted by SprueOne on Saturday, October 8, 2011 8:30 PM
I'd go with the styrene cement method. Then you know they are or are not styrene. The other material is that IM toy plastic that isn't resin or styrene Huh?
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    September 2005
Posted by Sprue-ce Goose on Saturday, October 8, 2011 8:35 PM
SprueOne
So long as the material used is not resin , then I should be able to saw the material without concern for my safety.
    January 2006
Posted by SprueOne on Saturday, October 8, 2011 8:46 PM
The Rommel Rod is 1/25 - 1/24 scale? A dust mask and an open window (two for cross draft if possible) for vapor is all that is needed at this scale of cutting and modification
Tags: MSDS
Posted by ajlafleche on Saturday, October 8, 2011 9:01 PM
Resin comes in a wide variety of colors. I've seen figures in yellow, white, creamy white, light gray, dark gray, even blue or pink.
Resin dust is inert; plastic dust is inert, saw dust is inert. None is more or less toxic than the others. You're more likely to have problem with regular old house dust than any of these. When you get tested for allergies, theu don't test for resin or plastic. These are all, however, iritants, i.e., they'll cause you to cough or sneeze if you ingest them. If you have a problem, a simple dust mask or bandana will rptect you from the dust. In large quantities, far more than any of us will generate cleaning resin or plastic, may be highly flammable, jujst as large quantities of flour can be very combustable.
As to glueing them, CA will work on them be they plastic or resin.
Ifyou really wanted to test them, I guess you could put a match to one. Plastic  will definitely burn...many model ships met that fate in my misspent youth, but I don't think resin will.
    June 2008
Posted by Hans von Hammer on Saturday, October 8, 2011 10:55 PM
Styrene will burn smoothly, with copious amounts of sooty smoke, and it will melt easily...  Resin will burn with the same smoke, but will won't melt, and it WILL sputter, and bubble and generally behave badly...
Also, it can't be stretched like styrene sprue, it just breaks... Plus, if you sand it, then sand the styrene, the difference is rather striking in the sanding dust.. There's a LOT of it with resin, far more for the same amount of sanding with styrene..
Ditto... Irritant, yes, toxic, no...
Resin is only toxic while it's a liquid, both as an inhalation and ingestion-hazard (the catalyst especially) and a splash hazard... It can cause chemical burns to exposed skin as well..  Don't spill it on your skin, and don't pour it in your eyes or drink it, m'kay?
Now, were you to be sanding resin parts on say, an industrial scale, eight hours a day, 40 hours a week, then air-quality standards set by OSHA have to be met and the proper safety equipment furnished and worn..
For most modeler's purposes, we don't get exposed to nearly enough of the stuff to make a difference, even over the course of a lifetime of modeling, unless you've already got some pretty bad respiratory issues t begin with..
Don't sweat it, unless it makes you feel better, psychologically, about it...
    September 2005
Posted by Sprue-ce Goose on Sunday, October 9, 2011 12:32 AM
Thanks, SprueOne, ajlafleche and Hans for the good suggestions and info.
I've read so many warnings about resin dust in modeling magazines, I presumed it was especially bad.
I will take normal precautions about where and how I create any dust from cutting the items.
    June 2008
Posted by Hans von Hammer on Sunday, October 9, 2011 10:39 AM
No sweat... I said "most modelers" to leave out those who built models for movies like Star Wars and such, since they make HUGE resin parts and cut/sand them with large power-tools...
Posted by Don Stauffer on Sunday, October 9, 2011 11:11 AM
The easiest way is smell.  Some people have sensitive enough noses to just smell the part and can tell right away.  Sometimes I file or sand a little on the sprue attachment or gate area and smell the dust (carefully, inhale as little as possible).  This will definitely smell enough to tell.  Urethane resin smells really stinky compared to styrene.
    June 2008
Posted by Hans von Hammer on Sunday, October 9, 2011 12:23 PM
Heh.. Wish I could.. My nose has been broken so many times, I'm afraid to sneeze, lest it fly off across the room..
    September 2005
Posted by Sprue-ce Goose on Sunday, October 9, 2011 3:29 PM
Well, here are the results so far:
1- Doesn't melt or smoke / burn like styrene when heated over a flame
2- Glue for styrene has no effect
3- very hard
4- very brittle
5- no odor released from a saw cut.
Considering the info posted by all , I am going to guess the substance used to make the Halloween decorations  is a type of resin and will be treated as such when I saw and trim it.
Many thanks to all for the informative and helpful suggestions !
Posted by Anonymous on Wednesday, October 12, 2011 3:41 PM
Taste test...resin is more bitter...
    September 2005
Posted by Sprue-ce Goose on Wednesday, October 12, 2011 4:15 PM
Manstein's revenge
Something like posts on locked threads?
    March 2005
Posted by TarnShip on Wednesday, October 12, 2011 5:00 PM
Sprue-ce, next time this comes up, just use the simplest method,,,,,,take a piece of sprue from a styrene kit and try to glue it to the sprue from the Subject kit, or a place out of site
if they bond, they are styrene, if not,,,it's resin or something different
I had to do this with an old Jenny kit I got at a show, I couldn't tell which it was from the molding,,,,,,the sprues welded with Testors, so it's a styrene kit
only takes a few minutes this way
almost gone
    September 2005
Posted by Sprue-ce Goose on Wednesday, October 12, 2011 5:07 PM
Good point !
    August 2011
Posted by GreenThumb on Thursday, October 13, 2011 7:38 PM
You could also just take a piece and put a couple of drops of Tenax or similar on it and see if it softens.
That's pretty much what the last post said it just eliminates the trying to glue together part. Big Smile
    September 2005
Posted by Sprue-ce Goose on Thursday, October 13, 2011 10:26 PM
GreenThumb
Tried that.- one reason why I concluded it was resin.
I am somewhat surprised that so few resin color variations occur as I would presume the color is chosen by the manufacturer rather than mandated by the resin chemistry .
These white Halloween items are the only other resin product I have seen in stores that was not tan.
    December 2006
Posted by detailfreak on Thursday, October 13, 2011 11:06 PM
                            Taste,mmmmm taste like resin.
        Greg"Detailfreak"RowleyYes
[View:http://s172.photobucket.com/albums/w1/g-earl828/]  http://i158.photobucket.com/albums/t104/cycledupes/1000Roadwheels4BuildBadge.jpg
    August 2005
Posted by Phil_H on Thursday, October 13, 2011 11:54 PM
You have to remember that "styrene" is just a  general name for a polystyrene based plastic. There are many, many different blends and formulations utilising different addititves, co-polymers and "fillers" which can alter the plastic's properties (and reduce costs).  For a commercially manufactured mass-produced item, it would be more likely to be styrene or a styrene derivative than a polyurethane resin.
Posted by Anonymous on Friday, October 14, 2011 10:05 AM
Phil_H
...yes, and that's why different companies' styrenes have different properties/feels to them...some are more brittle; some are soft and some fall inbetween...I feel that Dragon's is a bit softer than Tamiya's, for example...
    September 2005
Posted by Sprue-ce Goose on Friday, October 14, 2011 9:24 PM
Manstein's revenge
 Phil_H:
Dunno about current issue kits, but Italieri's 1970s era plastic was very brittle.
Do you believe Dragon plastic tastes more or less bitter than Tamiya's plastic........?Wink
    August 2005
Posted by Phil_H on Friday, October 14, 2011 10:30 PM
Sprue-ce Goose
 Manstein's revenge:
 Phil_H:
Dunno about the taste, but after cutting on hard Tamiya plastic, cutting Academy plastic is like carving cheese.Huh?
    September 2005
Posted by Sprue-ce Goose on Friday, October 14, 2011 10:55 PM
Phil_H
 Sprue-ce Goose:
 Manstein's revenge:
 Phil_H:
Better it is like carving cheese and not cutting cheese........Embarrassed
    July 2003
Posted by Kugai on Wednesday, October 19, 2011 12:42 PM
ajlafleche
 This reminded me of something...
Is that true for all forms of resin?  I had a kit that included resin parts once that were a rust color.  Unlike any other resins I'd run into, this stuff started producing a faint smell similar to gasoline when I was sanding it.  I ended up putting the project aside and never got back to it, but though I'd ask about this for when I do get around to finishing it just in case.
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
