Issue with Future
    May 2010
Issue with Future
Posted by salvine on Thursday, October 13, 2011 11:17 PM
So I admit I have only used it on a kit or two but today I spayed it on the bow and stern sections of a Burke destroyer to lay down the decals for the landing areas......maybe I didn't let it cure long enough? it dried for about 7 hours. I placed the decal and as I moved it it pulled up the layer of future underneath. ideas? I did put a little decal set down under the decal first but that seems strange that it caused the issue? After all, that's why we put a coat of it down right? Any ideas? Also, the paint layer underneath is MM acrylics.
    May 2010
Posted by salvine on Thursday, October 13, 2011 11:45 PM
I think I got lucky with the haze. The decal pulled off 4 little spots of future when I removed it. My understanding is that when I spray a new layer of future it will smooth out the areas that were pulled off and blend the whole area together. Does that sound right?
    May 2010
Posted by salvine on Friday, October 14, 2011 12:08 AM
    October 2008
Posted by padakr on Friday, October 14, 2011 6:39 AM
I've had that problem, even after letting the Future cure for days.  I also have had the problem that I am not fast or precise enough with my decal placement when using decal set.  The decals would snug down in the wrong spot and I would damage them when I tried to fix them.  I switched back to using plain water to place the decal and then use decal set (or sol, or sol-va-set) after they were just right.
    March 2005
Posted by Devil Dawg on Sunday, October 16, 2011 3:00 PM
That's interesting. I've only had that issue when I didn't let the Furture cure for at least 24 hours. I've always used MicroSet & MicroSol with no problems on Future (with the above exception). And, now that I've said that, watch me have a problem with it from now on!! Stick out tongue
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    May 2010
Posted by salvine on Sunday, October 16, 2011 11:25 PM
 I mounted the decal on the helo deck with lots of water to get it where I wanted and then added a little micro sol and it turned out fine. A little cloudy for a couple hours but then cleared up. Since the decal from the bow was toast I hand pained the markings and it looks fine. The paint line areas have raised lined in the deck so it was pretty easy to paint with some thinned flat white over the future. I think the real issue was when I knew the decal was destroyed I lifted it off and it pulled the future up with it. Disaster averted.
