Aztek A470
Aztek A470
Posted by Anonymous on Friday, January 30, 2004 2:53 PM
Gidday,
I have the A470 which I have only subjected to what I would describe as limited use. It seems that the 'double action' is more closely resembling a single action airbrush. Every time I use it now, no matter which nose piece is placed on it, paint wants to flow with the first downward pressure. I am new to forum so forgive me me not having any knowledge as to whether this is a common fault.
If this problem is well known, can it be repaired?
Tim
Posted by tigerman on Friday, January 30, 2004 6:36 PM
I believe you have to pull the trigger backwards to release more paint. This would give give you double action. Welcome to the forums Tim. So if you pushed down only, you'd get single action only.
 Eric
Posted by maddafinga on Friday, January 30, 2004 7:10 PM
I'd bet you have some paint dried somewhere it shouldn't be and is causing the needle to stick out some. Look around the inside of it very carefully and imagine where paint might collect, then clean it very carefully as well. Hopefully that would get it.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Friday, January 30, 2004 9:35 PM
Timothy, no matter what you do, DO NOT soak the body in thinner to clean it. You will destroy the trigger all together!! I think that Madda is probably right, and you will need to clean out a paint clog.
Posted by Anonymous on Wednesday, February 25, 2004 11:21 PM
You forgot to adjust the airbrush. Read the instructions to do the calibration. The airbrush is designed to also work in single action mode. There is a thumbscrew in the back that you adjust. What you want to do is attach a jar of water and press the trigger down but not back. Adjust the thumbscrew in the back until no water comes out when you press the trigger all the way down but not back.
    July 2003
Posted by zokissima on Friday, March 5, 2004 9:17 AM
I think hungfarlow (hehehe, gotta find that name funny :) is right. Make sure you read the instructions on how to calibrate your airbrush properly. The A470 works as both a single and double action airbrush, and that cylinder near the back of it is used to calibrate the needle. To find out whether or not you have a paint clog, simply turn the know all the way to the left (I think it's left :) and you should see the needle tip protrude all the way out (about 2 mm). Press the trigger, and if stuff comes out, then something is wrong, as that should be the fully closed position.
Once again, review the instructions on calibrating the airbrush. It's a fairly decent one :)
