acrylic rod bending for stands
Posted by Anonymous on Saturday, January 31, 2004 11:29 PM
I've been pondering leaving the gear up on the Hornet kit I'm building and making a stand out of 2 clear acrylic rods bent into a semicircular shape running from the tailpipes to a handmade wooden base.
What I was wondering is if any of yall have ever done anything like that and if so, where can I find acrylic rod that will do the job (3/8" looks about right). Also, if I can only find it in straight lengths (already found it online as such), how do you go about bending it to a perfect shape? I would need two exact bends so they would fit in the two tailpipes and fit evenly in the base I was planning.
Thoughts?
Posted by Anonymous on Sunday, February 1, 2004 4:19 AM
I've used clear acrylic rod to display a couple of planes in mid air. At the time I had a guy who was making clear cases for me and he provided the rod; I used 1/4". Unfortunately he has disappeared and there goes my source. I would suggest getting out the yellow pages and calling some plastic/acrylic suppliers. As to bending the rod, I used the wife's hair dryer and gently bent it into the shape I wanted. One thing to remember is to take into consideration the weight of the plane. For example, I wanted the F-16 I was mounting to have a slight nose up angle. I bent the rod into what I thought would work (I had already drilled the 1/4" hole in the walnut base), but when I attached the plane to the rod and the rod to the base, I had a nose down angle due to the weight of the plane. I had to start over, but on the second try I succeeded.
As to getting two pieces bent with the same curve, I would tape them together and use the hair dryer on both pieces at the same time.
    January 2003
Posted by stinger on Sunday, February 1, 2004 3:27 PM
Matt
I did a quick search here in the forum and came up with this:
http://www.aircraftresourcecenter.com/tnt1/101-200/tnt106_DisplayStand_Chung/tnt106.htm
Someone else mentioned somwhere that you can get acrylic rod at a Michael's craft store.
Do an advanced search in the forum for "display stand" and "plastic rod" and you may find more info. I only looked at one topic.
PS - If you search for "acrylic rod" you'll get about five pages of topics. I didn't wade through them, as many titles didn't seem to pertain, but maybe they do.
Hope this helps
stinger
May an Angel be your wingman, and the Sun be always at your six
Posted by Anonymous on Sunday, February 1, 2004 5:48 PM
Mattp:
That was me that sent you the suggestion regarding Michaels, also a suggestion for a bending jig, back in your A/C forum thread.
Regards,
Bruce
Posted by Anonymous on Sunday, February 1, 2004 6:05 PM
thanks for the ideas guys.
ive had a plan for the base, but wasnt sure how to bend the acrylic. i'll post pics when i get it all done. still have a ways to go on the model first - just wanted to make sure it was doable how I wanted before I went and glued the gear doors shut and whatnot
    January 2003
Posted by stinger on Sunday, February 1, 2004 7:35 PM
QUOTE: Originally posted by B. LeCren
Mattp:
Regards,
Bruce
Bruce - It was you who recommended Michael's, but I was referring to your reply to a post back in Sept. Wink [;)]
See here:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=7661
Dick - I like your idea of using the hair dryer. Much more controllable than the oven technique in the link I posted above.
Matt - Yeah, Buddy, let us know how it turns out!
stinger
