Just can't finish
    December 2011
Just can't finish
Posted by ExtraDriver on Monday, December 12, 2011 4:45 PM
I get to around 80% finished on most of my kits and then can't seem to do the last few bits. Armour or air, I have hundreds of kits, and many hundreds of paints, and all the tools imaginable. Finished tanks that lack only the tracks, minor imperfections in an aircraft paint job, and the model is no longer perfect so instead of fixing the problem the kit goes on a shelf and I move on and start the cycle with yet another kit. I have around five or so at any time on my bench.
Is there any mental trick to get over this? It seems I would ether move on than finish a kit that was'nt perfect.
    May 2008
Posted by Boba Fett on Monday, December 12, 2011 4:49 PM
Happens to everybody. I am ESPECIALLY guilty of it. I probably have about 20 kits stashed around in varying states of completion. I get 1 little problem and the whole thing goes downhill. Then I open a new box, "Oh man, NOW I'm gonna do it right!" and the cycle continues. Probably why I've started to do more figure painting as opposed to armor/aircraft.
Dre
    June 2007
Posted by Dre on Monday, December 12, 2011 4:53 PM
I'm like you in that I have several unfinished kits lying about, gathering dust.
One thing I do to motivate myself into finishing these shelf queens is to set a goal:                                               I can open and start this kit, but at the same time I have to finish this other one by the end of the month.
If you think that there's a reason for getting it done, then it might get done.  Besides, if you finish one old kit then you can reward yourself by starting two more new ones!
    December 2011
Posted by ExtraDriver on Monday, December 12, 2011 5:02 PM
Thanks for the tips- it's good to know that the phenomenon is not uncommon. However, the closer to completion I get, the more stressed I get about the last few parts or decals, and somehow feel it's not perfect, and it gets put away.
I justify this by saying it's just a hobby, and if I want stress I can go back to work! Still would like to finish something once in a while.
Posted by tigerman on Monday, December 12, 2011 6:59 PM
Sometimes you just have to finish it, even if you know it's not where you'd like it. I've done that and then gone back and said "You know, it's not all that bad......to me".
Another way to get them done is to join a Group Build. With all the fun and excitement of watching others build, it motivates you to do the same.
 Eric
    May 2006
Posted by Bill IV on Monday, December 12, 2011 7:20 PM
Well, it *is* just a hobby, but I also have kits I started in a different century, different area code, in a different marriage, with different hopes and plans for the future.
My aspirations usually exceed my ability, and I far prefer starting or being in the middle of figuring out something, when the mistakes aren’t so apparent, or irreparable, when the illusion of perfect results still persists.  So its fairly hard for me to finish the last 2 or 3 percent of a build- the touch-up painting, the last antennae. I live with models in progress so long, I get used to them not being done, it doesn’t bother me as much as it might.
An easy test for this is whether you're ready to take the 'final picture' of the model. I sometimes take that picture and then I see what I need to go back and work on - paint boo boos, missing small parts, decals in the wrong place. With effort, I go back and eventually fix these details, or I declare victory... but when I leave them with fixable problems - paint or alignment, for example, it tends to gnaw at me. In the old days, firecrackers could solve that problem, these days, not so much.
I’ve had multiple kits in progress going back to the early 1970s- 40 years. As my skills improved (and they have) it can take even longer to complete a kit, if its going to be satisfying. Trying to keep the number in progress under control, I’ve been tracking what I have going and what is getting done on it.
Half of what was in progress 10 years ago is now done, and I have 60 or so in progress now, most of which were started in the last 10 years.  I keep the running chart in my note book- one kit per line, one month per column. I put a single letter in the square for each of a number of fundamental steps in building: Cutting; sanding/filing/shaping; gluing; painting; decals; I go back and forth on whether doing research should be logged or not. Thinking about working or preparing without doing actual work doesn't count!
Looking at the chart can suggest sequences - I can do that and then do a cleverer version here and an even cleverer version there... Or prove that I have actually done something when I feel sorry for myself.
The present page has 2009, 10 and 11, with space for a few months in ‘12. I could get 3 more years onto the following page, but I’ve discovered that things do change in a few years time. Better to show whats active at the top, drop what’s finished or put away. Only 30 of the 60 I’m tracking have had any work done since October of ‘09.  And I don't think a default data space for a 6 year build is all that clever an idea....
I have completed 12 of the 60 or so kits my wife and son have given me at Christmas and birthday, in the last 16 years, and another 25 or so that I bought, were gifts from friends, etc. I also completed several dozen 1/700 air racers, airtankers for fighting fires and airliners, along with the obvious military subjects the kits are intended to protray. I have another 50 or so half  completed, but they don’t count the same as a 1/144 or 1/72 kit.
I don't know if this makes me smarter or makes me an accountant, but I wouldn't stop doing it.It gives more illusion of control!
Bill
    February 2010
Posted by Stage_Left on Monday, December 12, 2011 7:21 PM
Nope, this phenomenon is definitely not uncommon. I feel the same at times as I get to the decaling and finish, but my mental trick is to just say that I'm going for it. Most of the real world articles we're copying are imperfect in their finishes anyway, so that helps. Another mental trick I do is to make each step like a micro-step. It's slower that way, but only think about the very next thing you'll do, and do that without considering what's after. Before you know it you'll be putting paint down or clearing for decals. I know when I finish something that trumps the feeling of whether the end result is perfect or not.
    July 2003
Posted by Kugai on Tuesday, December 13, 2011 1:20 AM
Don't ask me.  I have a few that just have the decals left to go and I still keep getting distracted to where they're not done yet.  I do have an excuse with one of them: I'm still trying to figure out how to get a "nose art" type decal together without the printer option.
Of course, if I ever do get around to the needed "decal and final dullcote" marathon weekend to wrap these up, it'll be a lot of stuff to post pics of in a short time...
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    December 2011
Posted by ExtraDriver on Tuesday, December 13, 2011 6:29 AM
Perhaps a look back would be useful to see why kits aren't finished. For me it seems to fall into two groups: assembly going well until faced with an extremely boring or tedious step, like assembling individual track links, installing 30 photo etched seatbelts in a Trumpeter C-47, or some major egregious error that looks bad or is impossible to fix, major canopy damage, trying to fix the wings down on a Trumpeter kit, trying to get straight barrels on an Ontos, etc.
Some failure to finish comes from boredom, but most of mine come from the above. Some of these are deign flaws that make it nearly impossible to correct, like Trumpeter folding wings.
Posted by Anonymous on Tuesday, December 13, 2011 6:40 AM
I pay a big guy to come over to my chalet once a month and beat the living crap out of me if I haven't made any progress or suffer from the "95% sYNDROME"---EVEN THAT DOESN'T KEEP MY FROM NOT FINISHING MANY BUILDS...
    August 2006
Posted by K-dawg on Tuesday, December 13, 2011 10:51 AM
It happens, sure. What usually works for me is going back and thumbing through photos, references and or whatever gave me the inspiration or motivation to start it... Often times that will reignite the desire to finish it. Taking in progress pictures seems to help as well.  Going back and looking at the pictures and seeing again all the work you have put into it till that point can sometimes push one to finish it. Just a couple of suggestions but yeah, i defiantly know what you're going through... I have a couple in that state myself, most have sat idle for several years.
Kenneth Childres, Central Arkansas Scale Modelers
    January 2009
Posted by fermis on Wednesday, December 14, 2011 12:07 AM
Forget "perfect"......it never happens. And don't sweat the small stuff. I look back at some I've done earlier in the year (finished 33 so far BTW) that I wasn't all that happy with at the time, but I don't really notice or even remember what the issues were, to begin with. I hit "snags" with almost every project, I make myself do it, don't think about it and within 5 minutes I'm fully into what I'm doing. I'm normally a one at a time builder, start to finish. Lately though, I've been working in pairs. While parts dry on one, I work on the other. Any more than two, and I don't think I'd finish nearly as many.
    December 2010
Posted by TheWildChild on Wednesday, December 14, 2011 12:45 AM
yeah that seems to happen alot to me as well. i limit myself to 3-4 projects at a time, and wont start another until one of them is entirely done........usually does the trick. Manstien's idea seems pretty effective as well, although alot more painful lol.
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
Posted by Tojo72 on Wednesday, December 14, 2011 8:59 AM
just do it
    October 2008
Posted by oddmanrush on Wednesday, December 14, 2011 10:16 AM
Blame the stash....I never had this problem until I developed a stash. Before I accumulated my meager collection, I would build a model and if I reached a difficult spot I had no choice but to continue. I bought and built one model at a time...it was all I had money and time for. When I started attending shows, I was lured by cheap prices at the vendor tables making me capable of purchasing 2, 3 or 4 models for the price of one. My stash still is not that large compared to most of the gentlemen/ladies on this site but its large enough to derail me from current builds that have either lost my interest to an attractive young kit in the stash, or have hit a rough patch of difficult fit, or poor instructions. In some cases, I put a model down to let the glue set and start another one...its a poor habit but I think every one encounters it to some extent.
What can you say, except don't do it. Its something you have to think about, to get over that last hump. There isn't a trick to it, at least none that I know of, except to just bear down and finish. To help myself, I'm not likely going to purchase more models until I've finished the ones I've already got.
Jon
My Blog: The Combat Workshop
    January 2009
Posted by fermis on Wednesday, December 14, 2011 10:49 AM
oddmanrush
...... I'm not likely going to purchase more models until I've finished the ones I've already got.
HAHA, good luck with that!!!Toast
    October 2008
Posted by oddmanrush on Wednesday, December 14, 2011 10:56 AM
fermis
 oddmanrush:
A guy can try eh, amiright? Whistling
Jon
