OK Hans, the stripping award goes to you!!
I tried lacquer thinner first and it had absolutely no affect, even after soaking for a few minutes. It did clean the coating very nicely though! Maybe the coating isn't photo resist?
I then tried the lighter method. This worked but I was worried about the fumes from the burning coating. I do have a respirator, but with the cold wet weather here in the bay area I decided to leave my windows closed. Also, I didn't want to anneal the brass as all the bends in the PE were very simple and I didn't really want to soften the metal. However, since it worked I decided to save it for my last option.
I don't have any more straight MEK left, but I think Tenax 7R is mostly MEK so I tried it and after a little scrubbing with a stiff nylon brush the coating started to dissove and flake away. It took about 15 minutes to gently scrub away the coating off the entire fret. I did put on my respirator even though Tenax doesn't have much odor and I wore nitirile gloves to protect my skin. After brushing off the residue and giving it a light sanding with some 600 grit sp the PE is now shiny brass and ready for use!
Thanks again guys for dropping in those tips!!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
