Scraps
    February 2012
Scraps
Posted by Joewat64 on Monday, April 2, 2012 12:50 PM
Where can I get some scrap models or parts like wings and other large parts to practice AB on? I want to try different ways to thin to see how they work and spray but don’t want to take a chance on the model I’m working on. Does anyone sell scrap kits?
    June 2010
Posted by DoogsATX on Monday, April 2, 2012 12:56 PM
I just use the kits that went bad.
I've got a 1/48 Revellogram Dauntless that I hated. So it became the Fail Dauntless, paint mule extraordinaire.
Had a Fail Lightning for awhile (dog destroyed it mid-build),  but tossed it during the move since it was a shattered wreck.
My latest is a Tamiya Ki-84. Glued the cowl gun cover on backward. Welded inside and out with Tenax. Removing it would be rather destructive, and I've got newer Hasegawa kits in the stash now. So...it's the Fail Frank. Just used it a few days ago for some chipping experimentation.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    January 2009
Posted by Griffin on Monday, April 2, 2012 1:14 PM
You could buy a cheapo Airfix kit and just glue the body together.
Posted by Tojo72 on Monday, April 2, 2012 1:23 PM
If you don't have any old kits gone bad,then you may have to spring for a cheap practice kit,maybe a show vendor or garage sale,flea market.I usually practice on older stuff or trashed kits.
    September 2005
Posted by Sprue-ce Goose on Monday, April 2, 2012 1:26 PM
Don't even need old kits.
Sometimes, broken toys are made of a paint-able plastic.
    November 2003
Posted by bobbaily on Monday, April 2, 2012 2:20 PM
A plastic milk jug/juice container with a coat of cheap spray can primer will do the trick
Bob
    June 2010
Posted by DoogsATX on Monday, April 2, 2012 2:24 PM
bobbaily
My issue with those is that it's tough to get a sense of how a technique plays out on the contours of an airframe...
    November 2003
Posted by bobbaily on Monday, April 2, 2012 2:54 PM
DoogsATX
 bobbaily:
Agreed....I keep both-an old Monogram Zero and a primered plastic juice container for my test purposes.
Bob
cml
    March 2007
Posted by cml on Monday, April 2, 2012 6:56 PM
DoogsATX
 bobbaily:
If it's just for learning how to a/b, i think they're ok.
Not sure about the US, but over here, we have plastic ice cream containers.  The plastic is somewhat similar to sheet styrene (particularly the lid, not so much the tub itself).  I find it to be pretty good for a/b practice.
Having said that...and to make myself look like a hypocrite...i did have a failed Hasegawa Intruder that i practiced on too, many years ago.
Chris
    February 2012
Posted by Joewat64 on Monday, April 2, 2012 8:23 PM
Geat tips. Thanks everyone.
    April 2009
Posted by Cadet Chuck on Monday, April 2, 2012 8:42 PM
Go to Hobby Lobby and pick up a couple of cheap, crummy Revellogram kits-
    January 2009
Posted by fermis on Monday, April 2, 2012 9:55 PM
I just close my eyes, spray the model, and hope it all works out!
Posted by Don Stauffer on Tuesday, April 3, 2012 8:58 AM
You know those clear plastic blister packs that everything comes packaged in these days?  A coat of primer and they make good practice material.
    November 2003
Posted by bobbaily on Tuesday, April 3, 2012 2:28 PM
Don Stauffer
Good point Don.
Pretty much anything with primer will work-the primer provides the consistency/baseline that you are looking for to practice air brushing or experiment with thinner/paint ratios, air psi, paints, etc.
Bob
Posted by Anonymous on Tuesday, April 3, 2012 2:56 PM
DoogsATX
http://i780.photobucket.com/albums/yy86/doogsatx/Fail%20Frank/file.jpg
...how did you achieve that camo effect and what type of airbrush did you use?
    June 2010
Posted by DoogsATX on Tuesday, April 3, 2012 5:57 PM
Manstein's revenge
 DoogsATX:
It was a chipping test. From left to right - prismacolor pencil, salt, AK worn effects fluid, AK heavy chipping fluid. Airbrush was an Iwata HP-CS.
