Modelling madness down?
    February 2008
Posted by mike_espo on Monday, May 14, 2012 2:37 PM
Having difficulty acessing Modelling Madness site. I get a HTTP 404 error....Confused
When I do a google search for a particular kit: Sword 1/48 N9M for instance, and then try to acess the site, I get the aformentioned error.
Anybody else having this problem?
thanks
On the workbench:
Trumpeter 148 MiG -21F
    August 2011
Posted by Blueline on Monday, May 14, 2012 3:24 PM
If its one of Scott's builds, you have to go to the URL and take the "s" off of SCOTTS, so it leaves just SCOTT.
Here is an example http://modelingmadness.com/scotts/mod/us/av8b.htm ... remove the bold, underlined s, and it works.  Took me awhile to figure it out.
    February 2008
Posted by mike_espo on Monday, May 14, 2012 3:45 PM
That works. Hmm
Why is this necessary now??
On the workbench:
    March 2005
Posted by TarnShip on Monday, May 14, 2012 6:39 PM
I just checked for you
the path on the site still works, also
MM home, site map, previews, S tab,,,scroll down to Sword 1/48,,,,then the review opens
I looked at the URL's,,,,the few I looked at, I didn't see a "scotts" in the URL, just a "scott"
but, I never used a search engine on MM,,,,,I've always just drilled down through the menus
I was just checking,,,,,probably didn't help much, haha
Rex
almost gone
Posted by waikong on Tuesday, May 15, 2012 12:17 PM
Most likely the site was reorganized. The pages used to be in 'scotts' but has since been moved to 'scott'.  Web search engines may not re 'crawl' a website for at least 30 days. So you will get out of date links to pages that no longer exist or have been moved.
    February 2008
Posted by mike_espo on Tuesday, May 15, 2012 1:10 PM
Thanks! That must be it. I can acess the main sight only. I have to remove the scotts last s.....frustrating.
On the workbench:
