Tips for Using ProWeld or SameStuff
    December 2010
Posted by BlakeyB on Tuesday, September 25, 2012 1:00 PM
Guys I just started working with Proweld. I use a touch and flow applicator which has worked great. I was wondering though, does anyone use a setting agent and if so what type to complete the bond faster?
Thank you experts
On the bench: Tamiya Bruiser 2012 RC Truck - Build Log here http://bit.ly/LJEMBr
    June 2010
Posted by DoogsATX on Tuesday, September 25, 2012 1:24 PM
How fast is it setting for you? I use Tenax more or less exclusively, and it sets to the point where I can ease up pressure in about 10-15 seconds, sometimes up to a minute if it's two parts that really need a forcing.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    December 2010
Posted by BlakeyB on Tuesday, September 25, 2012 1:38 PM
I would say about 1 minute. Which is fine for larger pieces I can clamp in place. But smaller parts that I have to hold in place with tweezers it can be a bit nerve racking to try not to shake at all.  With Model Master glue the thickness of the glue holds the lighter components in place but the end product is not as clean as proweld.  So I was hoping to use the proweld and maybe a setting agent to get the time down to 10 second or less.
    December 2010
Posted by BlakeyB on Tuesday, September 25, 2012 1:56 PM
Maybe I am just using too much then which is increasing the set time
    April 2009
Posted by Cadet Chuck on Tuesday, September 25, 2012 2:25 PM
Yes, Plast-I-Weld is the name - I have used it and like it.  Same goes for Tenax and Tamiya thin cement.  Tenax seems to be the fastest, but only by a little bit.  I don't think there is any kind of accerator available for these products.  Remember, they are solvents, not glues, and work by melting the plastic so the parts will weld together as the plastic rehardens.
    August 2012
Posted by Rambo on Tuesday, September 25, 2012 3:19 PM
I use Tenax for most stuff but for areas like big seams i use a thin superglue to hold then go back with Tenax and I guess you could say blend it together? then for really small parts I just use superglue Thick works good on small parts with no attachment places
Clint
    June 2010
Posted by DoogsATX on Tuesday, September 25, 2012 3:56 PM
Different plastics also come into play. The kit I'm working on at the moment - can't reveal as it's a commission build - but the plastic seems a lot more resilient to Tenax than I've encountered with other kits.
For small parts (that won't be under any kind of pressure) I prefer Gator's Grip glue. Holds well, has remarkable shearing strength, and gives you a bit more working time than CA.
    December 2010
Posted by BlakeyB on Wednesday, September 26, 2012 10:19 AM
Thanks for all the replys guys
Posted by Anonymous on Thursday, September 27, 2012 3:32 PM
I've never seen the need for an accelerator for Tenax or ProWeld...if anything that stuff sets too fast...
    April 2009
Posted by Cadet Chuck on Thursday, September 27, 2012 10:59 PM
Roger that, Manny!
