Spill resistant surfaces that are cheap?
    August 2005
Posted by corvettemike on Thursday, November 1, 2012 7:15 PM
I just rented a home that has a built in work bench in the garage. The owner has expressed while it is ok to use it for modelling, he doesn't want paint spilled on it. That being said what are some good spill resistant surfaces I can cover the table top with? Paper seems too porous as does cardboard. Lexan if I spilled liquid cement would be a bad situation. Glass seems like it might crack under pressure. Laminate maybe? Wax paper? A layer of tin foil under paper? Any suggestions appreciated :)
Rise my brothers we are blessed by steel in my sword I trust...
Arm yourselves the truth shall be revealed In my sword I trust...
Havoc Models
    February 2006
Posted by ruddratt on Thursday, November 1, 2012 8:50 PM
Good idea to stay away from lexan. That stuff is pricey! If the surface is flat and level, glass is actually a good option. You can pick up 1/4" salvage glass (material left over from other projects) at your local glass house for as little as $4-5/ft.sq. There's also arborite. It's durable, flexible, and comes in a variety of finishes.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    November 2008
Posted by mrmike on Friday, November 2, 2012 12:29 AM
I like 1/4" thick melamine laminated fiberboard, available in 4' x 8' sheets at cabinet shop suppliers or home centers. Usually they can bust it into smaller sizes if you need. It's cheap, bright white and impervious to common solvents - I use it as an "underlay" work surface, and clean off paint and glue residue with lacquer thinner. If you don't cut into the surface, it lasts a long time.
    July 2010
Posted by Subhuman1 on Friday, November 2, 2012 4:26 AM
Another thumbs up for the glass, I use 1/4" tempered glass (the same as you would use for glass table tops), and just lay it flat on your work surface.
Feels odd not to have the glass to work on now.
    September 2006
Posted by Blitzwing on Friday, November 2, 2012 5:41 AM
If the glass is on a flat surface then you won't have any problems with it cracking no matter how much pressure you put on it.
URL=http://picasion.com/]
    April 2004
Posted by Jon_a_its on Friday, November 2, 2012 7:17 AM
I'd favour a glass sheet with rounded edges to stop you getting cut up by the edge, with some thick cardboard to cusion it if necessary.
You can find those green cutting mats in large sizes, but stuff like EMA PLastic weld, will go straight through it... (don't ask how I know...)
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    January 2009
Posted by fermis on Friday, November 2, 2012 8:38 AM
I use 1/4" glass as well. Super cheap....it was left in the house when I moved in!
    August 2008
Posted by tankerbuilder on Friday, November 2, 2012 8:50 AM
MIKE,Hi and how,s the new work area? I would recommend going to a cabinet shop and seeing if they have an end cut or sink cut out, of CORIAN. My benchtop(with the CORIAN and a piece of TEMPERED GLASS from an old tower stereo) are now over twenty years old.
The CORIAN when really soiled or stained can be sanded(WET) cleaned and re-leveled.this works wonders.The glass was free.It came off that stereo that was in a dumpster..YUP,dumpster diving has let me fully equip my shop-even the power tools.Good luck and keep me posted---TANKER-builder
    October 2012
Posted by nagsheadlocal on Friday, November 2, 2012 8:52 AM
A sheet of OSB or plywood can be cut to size and tacked in place. I personally like a wood surface as it allows me to pin things in place. Alternately, you can often find boxes of wood flooring at surplus and overstock stores for very cheap. One of the interior walls in my shop is covered in very nice oak flooring I got for free - it was being thrown out at a nearby construction site and the builders were more than happy to have me haul it off. In fact, with the rise in dumping prices, most builders are glad to have you haul stuff away, especially residential contractors. Never hurts to ask.
    August 2008
Posted by tankerbuilder on Friday, November 2, 2012 8:55 AM
Amen, to that! that,s how I got the two by fours to build the main bench.If you are not greedy, they are glad to have you cart stuff away. less cost for them. TANKER-builder
Posted by Don Stauffer on Friday, November 2, 2012 9:16 AM
I cover my workbench with contact paper.  It does not let paint through except in areas where I have inadvertantly made knife cuts through the contact.  Now that I am getting the discipline to cut only on cutting mats the contact surface is quite durable, yet I can easily replace it when it gets too many paint and glue drips on it.
Posted by Texgunner on Friday, November 2, 2012 11:56 AM
I use an old car side window that I found in the garage of a house my wife and I rented when first married.  It fits my table and I cover it with a page from an out of date warbird calendar.  I must have a half-dozen of them around and I just cut out one page and tape it to the glass.  The grid on the calendar also comes in handy at times for aligning parts.  When it gets all funky, I just cut off another page.  And, it's always fun to look at the airplanes on the calendar.
Gary
"All you mugs need to get busy building, and post pics!"
    April 2009
Posted by Cadet Chuck on Friday, November 2, 2012 12:03 PM
I use foam poster board or remnants of cardboard used for picture frame mats.  You can usually find scraps cheap at the framing dept of Hobby Lobby.  I cut them to size to cover the bench and staple them down, then renew them as needed.
    August 2005
Posted by corvettemike on Friday, November 2, 2012 1:45 PM
All very good suggestions but so far I like that one Chuck. Cheap, non porous, and best of all easily replaceable.
Havoc Models
    May 2004
Posted by KINGTHAD on Friday, November 2, 2012 4:31 PM
give me glass......worked on it for years and luv it.
    July 2009
Posted by Back to the bench on Saturday, November 3, 2012 10:26 AM
I have used tempered masonite in the past on garage work benches. It is stiff enough to lay flat on a bench top and the tempered side is a nice smooth, hard finish. It is typically dark brown in color, you may or may not like that. Dense enough to wipe up paint spills and they won't soak through if you leave them, but you can't scrape off cured glue and paint repeatedly like you would be able to with glass. In our area it is $9 for a 4x8 sheet at Home Depot. Most home centers will cut materials to your requested size (within reason) with their panel saw for about $2.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10053&langId=-1&locStoreNum=4647&productId=202046928&storeId=10051#.UJU1YmLIcis
Gil
