How does Futre take paint?
    September 2006
Posted by rookie 104 on Wednesday, December 19, 2012 12:57 PM
I have never dipped my canopys in future. If you do so can you paint the frames after you have dipped the canopy or should you do it before you apply the future.
 How long do you let it dry?
Can you just fill a container with some future and dip instead of airbrushing it on?
Can you use a hand brush?
Thanks for any replies.
    April 2009
Posted by Cadet Chuck on Wednesday, December 19, 2012 1:12 PM
Best way is to dip canopy in Future before painting the frame.  Let the excess drip off, set it down in a dust-free area  on a piece of waxed paper to keep it from sticking, (maybe cover it with a box) and don't touch it for 24 hrs.
    January 2006
Posted by dirkpitt77 on Wednesday, December 19, 2012 1:31 PM
I dip all my canopies in Future, then paint frames as usual. I use MM Acryls and have never had a problem with paint peeling or flaking off. I do take care with the canopies after they're painted, however. I'm thinking that Future coat probably doesn't provide nearly as much "tooth" as a primer would, for paint to stick to.  I imagine the frames I've painted are probably pretty delicate. YMMV.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
fox
    January 2007
Posted by fox on Wednesday, December 19, 2012 1:35 PM
Ditto on Cadet Chucks instructions. After that you can paint the canopy frames as Future is an acrylic coating. I have brushed Future with no problems on places where decals will be going to provide a smooth surface. After the decals have set, you can spray Dullcote over the decals if you're going back to a flat finish or Glosscote if you're going to gloss. You can also put the Future on those spots with an airbrush. Either way it helps the decals to settle. Hope that this answers your questions.
Jim Captain
 Main WIP:
    January 2006
Posted by dirkpitt77 on Wednesday, December 19, 2012 2:08 PM
Don't Dullcote your canopy though!  You'll fog it!
    January 2003
Posted by CNicoll on Sunday, December 30, 2012 2:58 PM
Also, if you using Bare Metal Foil or some other masking agent, the Future helps protect against any left over adhesive residue - just take it off with GooGone or something like that.  The Future keeps the canopy nice and clear.
BTW, to remove future from a canopy (or anything else) - just soak overnight in Windex or other ammonia/water solution (but watch the fumes).
And if you ever get a 'buff' mark on the canopy and cant polish it away, try dipping into future as well.
On the bench:  Academy 1/72 B-17G 'Blue Hen Chick';  1/48 Tamiya Mustang III; Kitty Hawk 1/32 P-39.
Completed:  1/48 Tamiya P-51D Mustang - 'Show Bird', 1/32 Dragon P-51D  Flying Tigers 'What if'; 1/32 Tamiya P-51D Big Beautiful Doll
Group build:1/48 Tamiya Mustang III; 1/48 Tamiya P-51D Show Bird
